![]() | Home > Technical (L322) > Jump starting a 3.6 (New issue !) |
If the battery is totaly dead / flat these booster packs won't work. The breakdown operator will have a much higher capacity booster pack. 2012 TDV8 Vogue (L322) |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2588 ![]() ![]() ![]() |
Jaygee, this thing will jumpstart a 747 so it must be me, I dont think I am getting a good connection on the positive |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8744 ![]() ![]() ![]() |
If it’s a completely flat battery you have to press the override button.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8512 ![]() ![]() ![]() |
Just get one of these....!!!
Thanks chaps, however I do understand how to work the thing, just doesnt work on the 3.6 !! 2013 L405 Autobiography Baltic Blue
Pete, F |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3179 ![]() ![]() ![]() |
There's a sticker under the bonnet that says when jumping to switch the ignition on and wait 120 seconds before cranking. I wonder if that's to let the voltage and stuff stabilise when the initial load comes on. I've never had any issues doing it that way.
Thanks David, will try that that |
Rudyard1 Member Since: 15 Nov 2021 Location: Leicestershire Posts: 89 ![]() ![]() |
So strange you mention this because I have the same issue with my 3.6! Bloody NOCO starter won’t help mine when it’s dead either!! 2007 Range Rover Vogue 3.6 TDV8 |
had to bite the bullet and called the RAC, time will tell ..... hopefully telling me what I am doing wrong |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
As the yanks say there's no replacement for displament and the same holds true for battery packs.
John-suusex Member Since: 31 Oct 2019 Location: Sussex Posts: 53 ![]() ![]() |
To be honest i've never been able to start a 3.6 on a jump pack. tried a few inc ones that said would do a 7l... nope.. I feel you're pain 2008 TDv8 Vogue in Java black x2
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 705 ![]() ![]() ![]() |
Which NOCO pack was it ?
So after having been told its the battery I ordered a new one which arrived today, now key wont turn in the ignition, full power etc but will not budge, any pointers? thanks |
