Home > Technical (L322) > Jump starting a 3.6 (New issue !)
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Fellow masochists, I need some help. I have a NOCO booster and it has never let me down until now, TD6 no problem, L322 4.4 no problem, L405 4.4 no problem, L322 3.6 no worky, I am at my wits end, the RAC man starts it OK, what am I doing wrong, have tried it direct to battery, used the earth point etc, why did they change the live points (unless I am missing something), I can get no power to the car, HELP Big Cry 2013 L405 Autobiography Baltic Blue
2007 L322 Vogue Buckingham Blue
Post #708364 5th Jan 2025 3:00pm
JayGee
If the battery is totaly dead / flat these booster packs won't work. The breakdown operator will have a much higher capacity booster pack. 2012 TDV8 Vogue (L322)
Post #708370 5th Jan 2025 3:33pm
Rosco
Jaygee, this thing will jumpstart a 747 so it must be me, I dont think I am getting a good connection on the positive Thumbs Up 2013 L405 Autobiography Baltic Blue
Post #708372 5th Jan 2025 3:43pm
If it’s a completely flat battery you have to press the override button.
Only just got mine so literally just read the instructions for it. They time out after 60 secs and if the voltage is less than 3V you need to use the override function. 👍🏻 There is nothing that can't be fixed with a hammer😜😜
Post #708379 5th Jan 2025 6:00pm
Just get one of these....!!!
https://www.planestation.aero/product-deta...ng-747-APU
Rolling with laughter Rolling with laughter Rolling with laughter Pete
Post #708380 5th Jan 2025 6:02pm
Rosco
Thanks chaps, however I do understand how to work the thing, just doesnt work on the 3.6 !! 2013 L405 Autobiography Baltic Blue
Post #708384 5th Jan 2025 6:16pm
Rosco
Pete, F Big Cry Big Cry CK off xx 2013 L405 Autobiography Baltic Blue
Post #708385 5th Jan 2025 6:18pm
dhallworth
There's a sticker under the bonnet that says when jumping to switch the ignition on and wait 120 seconds before cranking. I wonder if that's to let the voltage and stuff stabilise when the initial load comes on. I've never had any issues doing it that way.
Post #708399 5th Jan 2025 8:41pm
Rosco
Thanks David, will try that that Thumbs Up 2013 L405 Autobiography Baltic Blue
Post #708402 5th Jan 2025 9:12pm
Rudyard1
So strange you mention this because I have the same issue with my 3.6! Bloody NOCO starter won’t help mine when it’s dead either!! 2007 Range Rover Vogue 3.6 TDV8
Post #708407 5th Jan 2025 9:56pm
Rosco
had to bite the bullet and called the RAC, time will tell ..... hopefully telling me what I am doing wrong Very Happy 2013 L405 Autobiography Baltic Blue
Post #709464 17th Jan 2025 5:58pm
sako243
As the yanks say there's no replacement for displament and the same holds true for battery packs.
Not a Land Rover but a mate had a dumper die on him at my place. He had several big jump packs (bearing in mind most of his vehicles are 4l+ Perkins lumps or 6l+ Cummins engines and nothing would touch it. Brought my JCB up and big jump leads (70mm2 welding cable) and with the JCB running at operating revs, circa 2200rpm (beauty of a hand throttle) the dumper fired straight up.
I've also got a NOCO and used the override but if the engine is a bit tighter or there's more electrical load in the 3.6 then it's still a small battery pack. The NOCO 150 is 88Wh, by comparison a relatively small lead acid battery is 1.2kWh. To put it in comparison if a starter motor pulls 100A then that's a 1.2kW load. It will kill an 88Wh battery in 4 minutes and Lithium won't be allowed to discharge that much. The 3.6TDV8 starter is rated at 2.7kW so half that. You might think that a couple of minutes cranking would be enough but the internal protection in the battery pack won't allow it to deliver that as it'll cause it to overheat, overdischarge or a combination. Ed
Post #709481 17th Jan 2025 7:01pm
John-suusex
To be honest i've never been able to start a 3.6 on a jump pack. tried a few inc ones that said would do a 7l... nope.. I feel you're pain 2008 TDv8 Vogue in Java black x2
2006 4.4 Vogue se
2000 P38 They aren't all bad!
1996 D1 3.9 es
1996 Volvo 850 GLT
Post #709575 18th Jan 2025 7:26pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Which NOCO pack was it ?
I've got a GB75 & it started 6 cars one cold day last year including my 3.6TDv8 3 times - all without a re-charge.
Critical is the waiting time after connection & before trying to start the poorly car.
Early on I noticed it wouldn't start my 3.6 IF I was impatient & tried to start it immediately.
Did you get the NOCO to start it in the end or sort ou what the problem was ? Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #709577 18th Jan 2025 7:33pm
Rosco
So after having been told its the battery I ordered a new one which arrived today, now key wont turn in the ignition, full power etc but will not budge, any pointers? thanks Thumbs Up 2013 L405 Autobiography Baltic Blue
Post #709995 23rd Jan 2025 7:06pm
