Home > My Range Rover > The New SHINEY thread.... |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8620 |
Ive had a quiet morning as SwMBO has gone out……
4th Jan 2025 11:43am |
I think the keeping it side has won the argument…..
4th Jan 2025 7:05pm |
I had an email back from unique auto developments about the car play adapter and it will work with mine. So I’ve put one on order
6th Jan 2025 8:31pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8274 |
Looking forward to hearing about it.... Pete
6th Jan 2025 9:21pm |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 226 |
Word of warning on the GBX packs - give it a charge occasionally as if the battery depletes over time the BMS kicks in and won't allow you to charge it, it's a known problem that Noco seem to be ignoring. I recently bought a 'dead' GBX 75 from Ebay for £50 and fixed it, as it had this exact problem. There is a fairly simple fix if it shuts down - widely shared on youtube. If it does fail, Noco are quite generous with warranty and let you keep the old unit after you confirm you cut the leads off it and disposed of it, you never know, you may end up with 2 booster packs. Don't ask me how many I have L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
6th Jan 2025 9:42pm |
Interesting. I wonder if it just affects the GBX or if the GB ones are also affected in the same way. Not to tricky a fix if it breaks by the look of it. Just needs a low charge putting on the + and direct - on the battery. I’m sure I’ve got a low wattage power supply somewhere in a drawer I could do that with.
6th Jan 2025 10:48pm |
