Home > Technical (L322) > Please help!!! Really stuck now... |
Ma Larkin Member Since: 14 Dec 2024 Location: hampshire Posts: 11 |
First thing we did... changed fuel filter. |
15th Dec 2024 3:09pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2494 |
Are you seeing cranking RPM on a diagnostic tool that would demonstrate that the CKP sensor is working? |
15th Dec 2024 7:39pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1773 |
What volts are at the rail pressure connector? |
15th Dec 2024 9:36pm |
0.3...Doesn't change when cranking either |
16th Dec 2024 9:21am |
I was thinking of confirmation of the 5V supply to the sensor rather than a dead sensor. |
16th Dec 2024 10:57am |
Ok. So this making my head hurt trying to work out what is happening here! And following pipes... Again... right back to the beginning but remembered something that I thought was really unusual, but put it out my mind. Why I don't know. I noticed fuel coming out of the return line from the HPFP. And today when going back over everything, took the return line off at the secondary pump, where fuel was coming out, under pressure, from the return line. So basically the fuel flow is being reversed! Return line from the tank is blowing fuel out. Only thing I can think now is the in tank pump has gone wrong... |
16th Dec 2024 6:12pm |
I would remove the fuel filler cap to rule out a tank breather issue. |
16th Dec 2024 7:28pm |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 572 |
Clutching at straws but have you investigated the possibility that the crash sensor has triggered in some way ?
16th Dec 2024 10:20pm |
