![]() | Home > Technical (L322) > Please help!!! Really stuck now... |
Ma Larkin Member Since: 14 Dec 2024 Location: hampshire Posts: 11 ![]() ![]() ![]() |
First thing we did... changed fuel filter. |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2604 ![]() ![]() |
Are you seeing cranking RPM on a diagnostic tool that would demonstrate that the CKP sensor is working? |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1797 ![]() ![]() |
What volts are at the rail pressure connector? |
0.3...Doesn't change when cranking either |
I was thinking of confirmation of the 5V supply to the sensor rather than a dead sensor. |
Ok. So this making my head hurt trying to work out what is happening here! And following pipes... Again... right back to the beginning but remembered something that I thought was really unusual, but put it out my mind. Why I don't know. I noticed fuel coming out of the return line from the HPFP. And today when going back over everything, took the return line off at the secondary pump, where fuel was coming out, under pressure, from the return line. So basically the fuel flow is being reversed! Return line from the tank is blowing fuel out. Only thing I can think now is the in tank pump has gone wrong... |
I would remove the fuel filler cap to rule out a tank breather issue. |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 649 ![]() ![]() ![]() |
Clutching at straws but have you investigated the possibility that the crash sensor has triggered in some way ?
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 207 ![]() ![]() |
Any news Ma? Did you resolve it and if so, what was it please? 2012 Vogue TDV8 in Aintree green over sand |
