Home > Technical (L322) > Please help!!! Really stuck now...
Ma Larkin
United Kingdom 2012 Range Rover Westminster TDV8 Barolo Black
First thing we did... changed fuel filter.
Post #706951 15th Dec 2024 3:09pm
GraemeS
Are you seeing cranking RPM on a diagnostic tool that would demonstrate that the CKP sensor is working?
Post #706983 15th Dec 2024 7:39pm
Mikey
What volts are at the rail pressure connector?
Post #706994 15th Dec 2024 9:36pm
Ma Larkin
Yes. Just checked that and all fine. Thank god, as changing the CKP was a nightmare! Didn't want to do that again in a hurry!
Post #707014 16th Dec 2024 9:20am
Ma Larkin
0.3...Doesn't change when cranking either
Post #707015 16th Dec 2024 9:21am
GraemeS
I was thinking of confirmation of the 5V supply to the sensor rather than a dead sensor.
Post #707023 16th Dec 2024 10:57am
Ma Larkin
Ok. So this making my head hurt trying to work out what is happening here! And following pipes... Again... right back to the beginning but remembered something that I thought was really unusual, but put it out my mind. Why I don't know. I noticed fuel coming out of the return line from the HPFP. And today when going back over everything, took the return line off at the secondary pump, where fuel was coming out, under pressure, from the return line. So basically the fuel flow is being reversed! Return line from the tank is blowing fuel out. Only thing I can think now is the in tank pump has gone wrong...
Post #707052 16th Dec 2024 6:12pm
GraemeS
I would remove the fuel filler cap to rule out a tank breather issue.
Post #707061 16th Dec 2024 7:28pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Clutching at straws but have you investigated the possibility that the crash sensor has triggered in some way ?
Airbags haven't gone off I take it, but the fuel cutoff may have initiated or tripped.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #707082 16th Dec 2024 10:20pm
toby1
Any news Ma? Did you resolve it and if so, what was it please? 2012 Vogue TDV8 in Aintree green over sand
Post #711023 4th Feb 2025 1:52pm
