Hi,
I did mine some time back and although in another thread, thought I'd paste here as well.
Collapsed O ring I replaced with this off EBAY, 18mm x 2.5mm, Viton Rubber FKM O Ring Seals: https://www.ebay.co.uk/itm/141455807142?var=441967645571
Previous Post
Finished changing out my leaking oil cooler for new Nissins unit today, bought new gaskets but didn't need them as the new unit came complete, so some spares up for grabs, I'll put up for sale at a discount later.
Also took the oportunity to replace all the oil, coolant etc. root around for anything untoward, nothing found really all of the pipes in excellent condition.
Couple of lessons learnt there so I'll add to the wiki guide:
1. the wee 18mm x 2.5 mm washer inside the right angled water junction on the cooler was perished so 2 day delay while a replacement arrived, did change the 2 small ones on the cooler rear though, should have got this one with the other bits Doh ! I also cut off that pipe clamp and replaced with a spring clip as it's easier to remove the water pipe from the connector due to other metalwork in the way, then take off the connector sans pipework as you want to be changing the O ring on the bench not in situ and definately don't want to be losing that spring clip.
 | Click image to enlarge |
2. The rear steel bracket that the plenum sits on, has 4 vertical studs and 2 horizontal ones, the two horizontal threaded studs way too long and hard to get it off without risking breaking something, so cut them down to 1cm long. Much easier, why they were 3cm long, no idea.
3. Tip, must remember not to tilt the oil cooler when removing it and put it staight into a bucket, there is still about 1/2 litre of oil and water in there, which I found when I inverted it for a look. so spent a while cleaning up the driveway with her indoors somewhat miffed at the mess.
So far all good, spilt oil will burn off over the next day or so even though soaked everything in brake cleaner.
Let's hope that's an end to it.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
