Home > Maintenance & Mods (L405) > Iced shut door
DaveBL405
United Kingdom 2019 Range Rover Autobiography SDV6 Balmoral Blue
Iced shut door
Obviously been a bit chilly in the UK this week. I set my car via the I control app to preheat for 30 mins before going out this morning. Car was nice and warm, windscreen had defrosted etc which was all great… but my drivers door was as fully iced shut and only some determined pulling mixed with some lukewarm water did the trick.
I’ve owned loads of different cars over the years in some really cold weather but I’ve never had a door feel liked it’s been welded shut by ice! Is this normal for an L405 or do I have a seal issue or something?
Post #704955 20th Nov 2024 8:27pm
mjdronfield
L322 does the same. Gummi pledge (think that’s it) or similar, on the rubber seals to stop them sticking.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #704959 20th Nov 2024 8:40pm
firstrr
England 2019 Range Rover Autobiography SDV6 Santorini Black
I’ve always used spray silicone (Halfords, Amazon etc), onto a cloth and wipe all rubber seals, it protects and prevents sticking. And, a spray on the hinges and into the door catch mechanism also helps. Used it for years.
Post #704966 20th Nov 2024 9:02pm
Arch Stanton
England 2018 Range Rover Autobiography SDV8 Corris Grey
ive always just put a light coating of a light oil (WD40 type) with a cloth on the seals of all my cars. Always worked, never any issues. First time FFRR owner
Post #704972 20th Nov 2024 9:36pm
Kot
Thanks for reminding me Thumbs Up 2018 SE SDV8 4.4 Byron Blue
Post #704973 20th Nov 2024 9:44pm
Merchy
Thanks for the info on the Gummi Pledge, at least I now know it is not a Haribo product Whistle
Post #704974 20th Nov 2024 9:47pm
Silverstone
United Kingdom 2016 Range Rover Vogue SE SDV8 Loire Blue
I had the same issue this morning trying to open my L405 doors. Tonight applied Gummi Pflege Stift. It is excellent stuff and after using my current bottle for a decade, I have ordered a new bottle from Amazon for £12.95 delivered Cool "There is no replacement for displacement" - W O Bentley
Post #704980 20th Nov 2024 11:16pm
Gremlin500
@ArchStanton:
That’s fine if it’s the WD40 Silicone Lubricant, but the Original WD40 (blue can) contains mineral oil which deteriorates natural rubber, the Gummi Pfledge silicone product is the most recommended on here.
The “Thetford” spray intended for caravan toilet rubber seals works well, it’s also silicone based, and cheaper the GPf. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #704983 21st Nov 2024 7:03am
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
There is a spray gummi and a sponge gummi, the sponge one seems to be more economical...
Post #704986 21st Nov 2024 7:44am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
+1 for the Gummi PfledgeStift (sponge one)
Been using it for years and door seal never stick - I usually do a couple of doses a few weeks apart in October or November and thats it..! Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #705161 22nd Nov 2024 5:40pm
E500
I gave my front door seals a good coating of gummi plfege yesterday, knowing it was going to be cold this morning.
I swaggered out to the car at 6.30am in -3 today, had the FBH going for 30mins too so was looking forward to jumping into my toasty motor.
Only to freeze my hands off trying to open the bastard frozen doors. Censored
Are you supposed to absolutely slather the seals in GF? I just put a thin coat on...
Post #705623 28th Nov 2024 11:50am
DaveBL405
I gave it a good coating with a microfibre cloth and it seemed to have worked this morning. However I found that when the door was iced shut before my yanking at it managed to rip the drivers door seal… SIGH
Post #705628 28th Nov 2024 12:33pm
SeldomSeenKid
Scotland 2008 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
I gummi pfledged all the seals at the end of the summer so the drivers door opened beautifully this morning.
Unfortunately my door lock was forzen OPEN so the door wouldn't catch. Laughing
Had to hit it with the heat gun for 15 minutes and gave it a few good slams. ---------------------------------
2008 L322 Supercharged
2007 Porsche 987 Boxster S
2024 BMW iX3
Post #705635 28th Nov 2024 1:42pm
28capridave
United Kingdom 2014 Range Rover Autobiography SDV8 Santorini Black
Always used silicone spray on all my cars works a treat
Post #705860 1st Dec 2024 8:13pm
E500
One of mine was torn when I got the car. Are they easy enough to replace? The part doesn't seem expensive.
Post #705907 2nd Dec 2024 2:23pm
