Home > Maintenance & Mods (L405) > Does the IID Tool have a brake bleed function for the L405 ? |
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 140 |
The GAP tool does have the ABS bleed function and I think it is under the ‘Service/Test’ menu. However it will not work on my car, I just get an error message. I have emailed GAP about it but still not had a solution.
12th Sep 2024 5:26am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1394 |
Hmm, I'll try and update mine, but it doesnt show that option in the service menu. That said, I did have the beta-version of the firmware to unlock a few other features, and maybe the bleed procedure isn't part of that version.
12th Sep 2024 1:46pm |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 448 |
hi sorry old thread i know but looking at doing my soon and was wondering where the bleed nipples are under the bonnet ? thanks |
17th Nov 2024 3:02pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1550 |
After replacing all 4 brake hoses on my TDV6 and pressure bleeding in the usual sequence, I just couldn’t get a good hard pedal no matter what, I had to take it to my local indy & they had to run the ABS pump using LR Pathfinder, even then it took them a few attempts, so be prepared.
17th Nov 2024 3:46pm |
The bleed nipples under the bonnet on a RHD are in front of the RHS strut mount casting. Its a black metal box with pipes running into the back of it, and another 2 downwards underneath it. The 2 bleed nipples face directly forwards horizontally. Bleeding these definitely made a difference.
17th Nov 2024 8:13pm |
thanks never did know there were bleed nipples in the engine bay |
17th Nov 2024 8:18pm |
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 162 |
After replacing the flexy brake hoses my pedal felt a bit spongy. Of course I started to question myself if it was like that before I did the work and couldn't be sure. I bled them umpteen times using a pressure bleeder and they're still the same. The brakes work perfectly but a soft pedal compared to my other car (P38)
18th Nov 2024 1:55am |
i take it the engine bay bleed nipples are the last ones to be bleed ? |
19th Nov 2024 3:14pm |
I would do them first personally to purge any air out at the top end from the outset of the procedure ... can do them at the end as well ... no harm !
20th Nov 2024 6:39pm |
thanks ....ive got a pressure bleed kit which i have used before so fingers crossed that should be ok |
21st Nov 2024 3:16pm |
I’d read somewhere that it’s best to pressure bleed them AND have a mate pump the pedal to get absolute maximum flow of fluid to purge the air out, -anyone done that? (with the ABS pump running?)
21st Nov 2024 4:09pm |
I’ve got 4ltrs of brake fluid so that should be enough ….and the wife thought she didn’t have to do anything |
21st Nov 2024 4:39pm |
Sounds like a recipe for a divorce:
21st Nov 2024 4:55pm |
yea been there ..ive just read the wsm ref bleeding the brakes and it recommends 28 pumps per side (rear) and 10 for the fronts my god if i asked the misses to do that many times id have a black eye best get my mate round save any hassle |
21st Nov 2024 5:35pm |
