Home > Maintenance & Mods (L405) > Does the IID Tool have a brake bleed function for the L405 ?
fisha
Cause I cant seem to find it in the app Confused
Currently going through all the calipers giving them a clean, pads, new rear pistons etc, and whilst they've been off, I've just let the fluid drip out the hose into a catch bucket, so a reasonable amount came out.
Whilst I'll follow the brake bleed process as per the workshop manual, I'm asking myself whether I should be purging the ABS unit, and that normally needs a command to make the pump run. I dont see the option in the iidtool app when connected, so just wondering whether its my app, or if its just not there as a function at all ? V8 or else ...
Post #699953 11th Sep 2024 8:55pm
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
The GAP tool does have the ABS bleed function and I think it is under the ‘Service/Test’ menu. However it will not work on my car, I just get an error message. I have emailed GAP about it but still not had a solution.
You shouldn’t need to use the ABS bleed procedure unless you have changed the master cylinder or ABS unit. Standard bleeding can be done in the usual way.
There are also two bleed nipples under the bonnet - I bled from these also and have a very good pedal and fantastic break feel.
Post #699958 12th Sep 2024 5:26am
fisha
Hmm, I'll try and update mine, but it doesnt show that option in the service menu. That said, I did have the beta-version of the firmware to unlock a few other features, and maybe the bleed procedure isn't part of that version.
That said, I've done a manual bleed this morning and the pedal feel is so much better than before when parked up, so hopefully i'll not need any iidtool stuff. V8 or else ...
Post #699983 12th Sep 2024 1:46pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
hi sorry old thread i know but looking at doing my soon and was wondering where the bleed nipples are under the bonnet ?
thanks
Post #704646 17th Nov 2024 3:02pm
Gremlin500
After replacing all 4 brake hoses on my TDV6 and pressure bleeding in the usual sequence, I just couldn’t get a good hard pedal no matter what, I had to take it to my local indy & they had to run the ABS pump using LR Pathfinder, even then it took them a few attempts, so be prepared.
In my defence, I didn’t have my GAP tool then Embarassed
Remember what Fergal Sharkey said……. Very Happy “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #704650 17th Nov 2024 3:46pm
fisha
The bleed nipples under the bonnet on a RHD are in front of the RHS strut mount casting. Its a black metal box with pipes running into the back of it, and another 2 downwards underneath it. The 2 bleed nipples face directly forwards horizontally. Bleeding these definitely made a difference.
I would say that whilst my brakes are good ( no squish ) I have in my mind they should feel a little bit more positive that then do at the moment. I don't have any lost squish of travel per-se, but I feel they should ramp up in firmness a little quicker. V8 or else ...
Post #704664 17th Nov 2024 8:13pm
will308f
thanks never did know there were bleed nipples in the engine bay Thumbs Up
Post #704665 17th Nov 2024 8:18pm
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
After replacing the flexy brake hoses my pedal felt a bit spongy. Of course I started to question myself if it was like that before I did the work and couldn't be sure. I bled them umpteen times using a pressure bleeder and they're still the same. The brakes work perfectly but a soft pedal compared to my other car (P38)
I've been told that the L405 has intentionally got a 'soft pedal' for more progressive braking. A year down the line and I'm used to it now.😐
Post #704684 18th Nov 2024 1:55am
will308f
i take it the engine bay bleed nipples are the last ones to be bleed ?
Post #704831 19th Nov 2024 3:14pm
fisha
I would do them first personally to purge any air out at the top end from the outset of the procedure ... can do them at the end as well ... no harm !
I'd say though that they are a 2 person job though as I noticed that on the up-stroke of the pedal, they drew back the fluid quite hard ... so you really want a open bleed, pedal down, close bleed, pedal up method, which takes 2 to do. V8 or else ...
Post #704944 20th Nov 2024 6:39pm
will308f
Thumbs Up thanks ....ive got a pressure bleed kit which i have used before so fingers crossed that should be ok
Post #705054 21st Nov 2024 3:16pm
Gremlin500
I’d read somewhere that it’s best to pressure bleed them AND have a mate pump the pedal to get absolute maximum flow of fluid to purge the air out, -anyone done that? (with the ABS pump running?)
Sounds like patting your head and rubbing your stomach at the same time, lol! Laughing
It’s not all just about getting air out, it’s equally as much getting all the Censored old water-absorbed brake fuel out, to prevent internal corrosion. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #705059 21st Nov 2024 4:09pm
will308f
I’ve got 4ltrs of brake fluid so that should be enough ….and the wife thought she didn’t have to do anything Rolling with laughter Rolling with laughter
Post #705063 21st Nov 2024 4:39pm
Gremlin500
Sounds like a recipe for a divorce:
“No! I said DOWN, not UP!” Rolling with laughter Rolling with laughter Rolling with laughter “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #705068 21st Nov 2024 4:55pm
will308f
Rolling with laughter Rolling with laughter Rolling with laughter yea been there ..ive just read the wsm ref bleeding the brakes and it recommends 28 pumps per side (rear) and 10 for the fronts my god if i asked the misses to do that many times id have a black eye Rolling with laughter best get my mate round save any hassle Thumbs Up
Post #705074 21st Nov 2024 5:35pm
