![]() | Home > Maintenance & Mods (L405) > Does the IID Tool have a brake bleed function for the L405 ? |
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 146 ![]() ![]() ![]() |
The GAP tool does have the ABS bleed function and I think it is under the ‘Service/Test’ menu. However it will not work on my car, I just get an error message. I have emailed GAP about it but still not had a solution.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1414 ![]() ![]() |
Hmm, I'll try and update mine, but it doesnt show that option in the service menu. That said, I did have the beta-version of the firmware to unlock a few other features, and maybe the bleed procedure isn't part of that version.
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 457 ![]() ![]() ![]() |
hi sorry old thread i know but looking at doing my soon and was wondering where the bleed nipples are under the bonnet ? thanks |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1584 ![]() ![]() ![]() |
After replacing all 4 brake hoses on my TDV6 and pressure bleeding in the usual sequence, I just couldn’t get a good hard pedal no matter what, I had to take it to my local indy & they had to run the ABS pump using LR Pathfinder, even then it took them a few attempts, so be prepared.
The bleed nipples under the bonnet on a RHD are in front of the RHS strut mount casting. Its a black metal box with pipes running into the back of it, and another 2 downwards underneath it. The 2 bleed nipples face directly forwards horizontally. Bleeding these definitely made a difference.
thanks never did know there were bleed nipples in the engine bay |
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 166 ![]() ![]() ![]() |
After replacing the flexy brake hoses my pedal felt a bit spongy. Of course I started to question myself if it was like that before I did the work and couldn't be sure. I bled them umpteen times using a pressure bleeder and they're still the same. The brakes work perfectly but a soft pedal compared to my other car (P38)
i take it the engine bay bleed nipples are the last ones to be bleed ? |
I would do them first personally to purge any air out at the top end from the outset of the procedure ... can do them at the end as well ... no harm !
I’d read somewhere that it’s best to pressure bleed them AND have a mate pump the pedal to get absolute maximum flow of fluid to purge the air out, -anyone done that? (with the ABS pump running?)
I’ve got 4ltrs of brake fluid so that should be enough ….and the wife thought she didn’t have to do anything |
Sounds like a recipe for a divorce:
