![]() | Home > In Car Electronics (L322) > Aux socket query. |
Glibbs Member Since: 18 Aug 2019 Location: West Somerset Posts: 113 ![]() ![]() ![]() |
Apologies - the volume control on the radio does indeed work but turning up to max is still quite low. Range Rover 4.2 SC
RobsterPC Member Since: 14 Oct 2024 Location: Kent Posts: 120 ![]() ![]() |
In my car (2012), while the ignition is on but not the engine, the Aux audio only goes so high. However, when you start the engine it goes much louder. I've got a cheap bluetooth to AUX adapter plugged in and it works fine, once you start the engine. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
I’ve got my CarPlay unit permanently cabled to the rear Aux socket and the volume range is perfectly acceptable .
Ah ha! Many thanks. Range Rover 4.2 SC
If you find that you need extra volume, it would be easy to conceal one of these amps to boost the level.
Many thanks. I've ordered one even if i ultimately won't need it in this case. Range Rover 4.2 SC
