Home > In Car Electronics (L322) > Aux socket query. |
Glibbs Member Since: 18 Aug 2019 Location: West Somerset Posts: 112 |
Apologies - the volume control on the radio does indeed work but turning up to max is still quite low. Range Rover 4.2 SC
15th Nov 2024 12:43pm |
RobsterPC Member Since: 14 Oct 2024 Location: Kent Posts: 115 |
In my car (2012), while the ignition is on but not the engine, the Aux audio only goes so high. However, when you start the engine it goes much louder. I've got a cheap bluetooth to AUX adapter plugged in and it works fine, once you start the engine. |
15th Nov 2024 1:08pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3785 |
I’ve got my CarPlay unit permanently cabled to the rear Aux socket and the volume range is perfectly acceptable .
15th Nov 2024 1:16pm |
Ah ha! Many thanks. Range Rover 4.2 SC
15th Nov 2024 1:23pm |
If you find that you need extra volume, it would be easy to conceal one of these amps to boost the level.
15th Nov 2024 1:33pm |
Many thanks. I've ordered one even if i ultimately won't need it in this case. Range Rover 4.2 SC
15th Nov 2024 1:50pm |
