Home > My Range Rover > 5 RRs and I have to give up |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7814 |
Should haveā¦.
10th Oct 2024 10:05am |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 541 |
Before we had our current 4.4TdV8's we had a 2003 M62 4.4Lt Petrol L322 and the steering weight feels very similar, I'd say the later cars are slightly 'meatier' but you can still easily slow speed steer with the heel of you hand. Drives: 2010 FFRR TdV8 Vogue - Stornoway Grey 2010 FFRR TdV8 Vogue SE - Zermatt Silver 1998 BMW E36 M3 GTII |
10th Oct 2024 10:23am |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 678 |
Thank you for the feedback all.
10th Oct 2024 11:45am |
Managed to get a few hours on the L322 today and do some investigation.
8th Nov 2024 5:31pm |
Moo Member Since: 09 Nov 2024 Location: BATH Posts: 3 |
Interesting thread. I'm looking at a L322 to run alongside my L663 Defender so this is all new to me although I've had many D3s and D4s. Current Car: L663 Defender known as Noddy. |
9th Nov 2024 1:30pm |
Been thinking about this some more and decided none of this is can be some weird voodoo or virus that only affects cars I own.
11th Nov 2024 9:22pm |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 693 |
I ended up creating a pressure test kit for my PAS when it was playing up & was consistently heavier than tolerable & i'd eliminated the Servotronic & BCU.
11th Nov 2024 10:06pm |
I was thinking about making up test equipment to see I'd it could shed any light
11th Nov 2024 11:00pm |
Any further thoughts on this anyone?
14th Nov 2024 8:57am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2494 |
The pump varies its displacement to maintain a constant pressure so a flow obstruction wouldn't cause a pressure increase. However I suspect that racks might not get set-up exactly the same all the time so rack/pinion preloading might be able to play a part.
14th Nov 2024 9:40am |
Sorry Graeme I'm not sure I follow you there, are you saying if there was an obstruction the pump wouldn't increase pressure to overcome it?
14th Nov 2024 9:50am |
I would expect any restriction in pipework etc to only cause a flow problem as any fluid getting through will allow full pressure to be generated, but might take longer.
14th Nov 2024 10:37am |
The pump is constant pressure, not constant flow.
14th Nov 2024 11:46am |
Very interesting info, thanks Pawl & Graeme.
14th Nov 2024 12:12pm |
