![]() | Home > Maintenance & Mods (L405) > Low SAPS 5W40 synth engine oil |
As a reference mine is regening every 80miles on a steady 65mph m-way cruise but can exttend to 150 miles if it involves long slower 50mph road work sections and non m-way driving. 2012 TDV8 Vogue (L322) |
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 171 ![]() ![]() ![]() |
Mine regens every 150 to 170 miles. I never get to the 200 to 300 that others seem to achieve. I've thought about the diy cleaning kits or even having the DPF cleaned professionally but would it make much difference?
What's your car's mileage? 2012 TDV8 Vogue (L322) |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1627 ![]() ![]() ![]() |
@Alex, I’m sure it only triggers on soot (which can be burnt off) and not on ash, which remains in there forever, hence the need for “Ultra-Low” SAPS oil, the only way to remove the ash is by physical means (flushing) as far as I understand it. There is discussion about some “treatments” harming the DPF, so proceed with caution.
What JLR are reffering to are fuel addatives for DPF 'treatment' and not oils. 2012 TDV8 Vogue (L322) |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 473 ![]() ![]() ![]() |
could be interested |
@JayGee, I think you misunderstood my post, Alex was talking about DPF cleaning above, to mitigate using the “wrong” oil, and I was advising caution in regard to that aspect. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 158 ![]() ![]() ![]() |
@Gremlin I am working on the assumption that the monitoring of the dpf is purely on pressure differential and can not distinguish between soot and ash causing the DPF needing to regen.
84000 TDV6 |
@Alex,
The ACEA specification is that all C grade oils - C1, C2, C3 and C4 are rated as ‘Low SAPS’ and suitable for DPF equipped vehicles. Yes C3 has a 60% increase in SAPS over a C1, but it is still at a low level.
@Alex:
M11buc Member Since: 06 May 2019 Location: Newcastle upon Tyne Posts: 44 ![]() ![]() ![]() |
Having read this thread I must say it’s a great discussion. Like many others I am very interested in the long term effects of different oil and grades. Look forward to see how it goes with different theory’s. I have a 2018 sdv8 euro 6 (with adblue) and for what’s it’s worth, I think moving to a 5/40 oil is a good thing. In my humble opinion after Doing a little reading I agree a euro 6 engine would require low saps (C1 or C4) oil. I have watched LR time with interest on the oil topic and trust he has done a lot of research, but his engines are not euro 6 and therefore guess his research lead him to conclude that a mid saps / DPF (C3) 5/40 is best for his requirements. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3879 ![]() ![]() ![]() |
Deleted. Geoff |
