Home > Maintenance & Mods (L405) > Low SAPS 5W40 synth engine oil |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
As a reference mine is regening every 80miles on a steady 65mph m-way cruise but can exttend to 150 miles if it involves long slower 50mph road work sections and non m-way driving. 2012 TDV8 Vogue (L322) |
8th Nov 2024 10:19am |
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 162 |
Mine regens every 150 to 170 miles. I never get to the 200 to 300 that others seem to achieve. I've thought about the diy cleaning kits or even having the DPF cleaned professionally but would it make much difference?
8th Nov 2024 11:40am |
What's your car's mileage? 2012 TDV8 Vogue (L322) |
8th Nov 2024 12:20pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1529 |
@Alex, Iâm sure it only triggers on soot (which can be burnt off) and not on ash, which remains in there forever, hence the need for âUltra-Lowâ SAPS oil, the only way to remove the ash is by physical means (flushing) as far as I understand it. There is discussion about some âtreatmentsâ harming the DPF, so proceed with caution.
8th Nov 2024 1:01pm |
What JLR are reffering to are fuel addatives for DPF 'treatment' and not oils. 2012 TDV8 Vogue (L322) |
8th Nov 2024 1:06pm |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 443 |
could be interested |
8th Nov 2024 1:09pm |
@JayGee, I think you misunderstood my post, Alex was talking about DPF cleaning above, to mitigate using the âwrongâ oil, and I was advising caution in regard to that aspect. âIf it ainât broke, donât fix itâ -whereâs the fun in that? |
8th Nov 2024 1:53pm |
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 140 |
@Gremlin I am working on the assumption that the monitoring of the dpf is purely on pressure differential and can not distinguish between soot and ash causing the DPF needing to regen.
8th Nov 2024 2:03pm |
84000 TDV6 |
8th Nov 2024 4:23pm |
@Alex,
8th Nov 2024 9:46pm |
The ACEA specification is that all C grade oils - C1, C2, C3 and C4 are rated as âLow SAPSâ and suitable for DPF equipped vehicles. Yes C3 has a 60% increase in SAPS over a C1, but it is still at a low level.
8th Nov 2024 11:19pm |
@Alex:
9th Nov 2024 12:33am |
M11buc Member Since: 06 May 2019 Location: Newcastle upon Tyne Posts: 43 |
Having read this thread I must say itâs a great discussion. Like many others I am very interested in the long term effects of different oil and grades. Look forward to see how it goes with different theoryâs. I have a 2018 sdv8 euro 6 (with adblue) and for whatâs itâs worth, I think moving to a 5/40 oil is a good thing. In my humble opinion after Doing a little reading I agree a euro 6 engine would require low saps (C1 or C4) oil. I have watched LR time with interest on the oil topic and trust he has done a lot of research, but his engines are not euro 6 and therefore guess his research lead him to conclude that a mid saps / DPF (C3) 5/40 is best for his requirements. |
16th Nov 2024 11:34am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3836 |
Deleted. Geoff |
16th Nov 2024 1:30pm |
