Home > Technical (L322) > Help! I’ve made a booboo
RobsterPC
Yup, those are the bolts.
Today's job is to get the pin out and then the new pads in so that I can drive it again. I'll order 4 new bolts them next week I can get the calipers off, paint them and replace the disks too.
This weekend I'll stick with rust treatment and under body protection I think.
Post #703048 25th Oct 2024 10:42am
RobsterPC
All sorted. I ended up using a long 6mm drill through one hole to drill out the other. A right pain.
My next problem is that I've not got any windscreen washer jets. I did have them but after changing the battery, I don't. Could this be the cause and if so, where does it go?
Post #703072 25th Oct 2024 3:45pm
Scouse Exile
Mine comes down the RH hinge, as you stand at the front, and disappears behind the battery into a harness. Without taking the battery out it’s hard to give you any specifics - in the second photo it’s the thinner black wire coming from the bottom of the screen
Post #703074 25th Oct 2024 4:01pm
RobsterPC
To close this out, I started with the obvious and simply topped up the washer bottle. Voila! Washer jets now working.
On to the next problem 😁
Post #703104 26th Oct 2024 11:17am
I think it maybe a good idea if you leave work on your Range Rover to a garage, it will probably be cheaper in the long run....!! Pete
Post #703105 26th Oct 2024 11:45am
RobsterPC
Where's the fun in that? 😁
Most things are doable but I also know when I'm in too deep. We were almost there this time but managed to recover just fine.
Post #703108 26th Oct 2024 12:54pm
I didn't think essential car maintenance to a safety system on a 2 ton projectile was supposed to be fun..!
If you can't diagnose no water in the washer bottle then what chance is there that the brakes will be changed successfully... Shocked Pete
Post #703109 26th Oct 2024 1:11pm
