![]() | Home > Technical (L322) > Help! I’ve made a booboo |
RobsterPC Member Since: 14 Oct 2024 Location: Kent Posts: 120 ![]() ![]() |
All sorted. I ended up using a long 6mm drill through one hole to drill out the other. A right pain.
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 395 ![]() ![]() ![]() |
Mine comes down the RH hinge, as you stand at the front, and disappears behind the battery into a harness. Without taking the battery out it’s hard to give you any specifics - in the second photo it’s the thinner black wire coming from the bottom of the screen
To close this out, I started with the obvious and simply topped up the washer bottle. Voila! Washer jets now working.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8374 ![]() ![]() ![]() |
I think it maybe a good idea if you leave work on your Range Rover to a garage, it will probably be cheaper in the long run....!! Pete
Where's the fun in that? 😁
I didn't think essential car maintenance to a safety system on a 2 ton projectile was supposed to be fun..!
