Home > General (L460 2022) > P550e useable without a home charging point?
if you have solar panels and its sunny, you dont pay anything.....just saying Very Happy ... - .- -.
Post #702850 22nd Oct 2024 5:26pm
Martin2
Unfortunately solar panels would have to be on the front of our house and they are just too ugly for the level of payback. For now. MY23 Panamera E-Hybrid
MY19 SDV8 Autobiography - Sold
Post #702852 22nd Oct 2024 5:38pm
NavinIyapah
Unnecessary quote removed
Thanks Jack, it seems from everyones experience that without having the battery charged the L460 hybrids do return the best MPG, as I expected. It's a decision about offsetting the cost of the purchase vs day to day fuel efficiency it seems! Thanks again
Post #702859 22nd Oct 2024 6:56pm
JackRegan
We have an average-sized 6kWh solar array connected to a 17.2kWh battery, enough for us to run the house for a day. We also have a home car charger.
With Octopus Intelligence Go, electricity between 23:30 and 05:30 is 7p per kWh. When the car gets plugged in, Octopus allocates an overnight time slot to charge the car to a set level by a certain time. So for me, it's 80% charge by 7 am. The solar battery is also set to charge overnight, so by 5:30 it's at 100%. After 05:30 the house runs off the battery. Solar generated during the day tops up the battery and the excess goes back to the grid, who pay 15p per kWh. At 23:30, the house switches to using electricity from the grid, rinse and repeat. 2024 P550e Autobiography
2016MY TDV6 Autobiography - Gone
2011MY 5.0 SC Autobiography Black - Gone
2005 TD6 Vogue - Gone
Post #702887 23rd Oct 2024 7:27am
Clipper
Do people think the P550e is worth it is versus p460e, including the dynamic enhancements?
Post #702894 23rd Oct 2024 10:37am
darren3005
United Kingdom 2015 Range Rover Vogue TDV6 Santorini Black
Merchy wrote:
I have no idea if you can set the charging time on the car, but if you were charging from a standard 13 amp socket you could use a plug in on/off timer for the 12.30 / 5.30 period, quite cheap and could be handy.
So as a side note I have an i4 full electric BMW, and I trickle charge from an outside 13amp socket fused inside the house. I mistakenly turned the switch of at the socket instead of unplugging the charger from the car first (as per manual) and the socket made an almighty pop when i did, gave me a bit of a shock i can say. Given I had two heart attacks in 6 years I won't be doing this again. You've bought WHAT!!
Post #702898 23rd Oct 2024 10:55am
JackRegan
I have thought this myself, as I find, when pushed the P550e is very quick. I'm sure the P460e is more than powerful enough.
However, I found price-wise (after discounts) that a P550e was similar in price to a P460e AB. This may be due to the 550e only being available in AB spec, whereas the 460e is available in SE, HSE and AB.
I managed to get a better deal on a new 550e than most new 460e AB. 2024 P550e Autobiography
Post #702902 23rd Oct 2024 11:37am
EdJ
I have the P550e, and whilst it's a fantastic car, I'm sure I would be just as impressed by the P460e.
There are times - usually on a long motorway journey - when I do miss the torque of a big diesel, but given how many shorter local journeys I do on electric, you cannot beat it. 2024 Range Rover P550e AB
Post #702903 23rd Oct 2024 11:42am
Clipper
Many thanks both.
I'm toying between p460e HSE versus P550e AB and therefore there is a fairly big £ difference, versus 460AB and 550AB.
Post #702904 23rd Oct 2024 11:51am
Renaco
Germany 2019 Range Rover Vogue SDV6 Corris Grey
I collected 10.000 mls in three months on German Autobahn, Swiss & Italian alps with my P550e.
For me it’s the smoothest RR I’ve ever owned.
The ride is comfortable and rather gliding, with surprisingly precise and direct steering. The vehicle oscillates slightly in the longitudinal axis, which is typical of RR, but should be a little less pronounced for my taste, especially as it is still present in dynamic mode.
As I have never driven an L460 without dynamic response, I would definitely recommend testing one beforehand.
For my taste, the driving feel of the P550e is perfect and balanced, it just shouldn't be any less damped and precise.
 RR Classic 1998-2005
MINI 40th 1999-now
RRS SDV6 2011-2014
RRS SDV6 HYBRID 2014-2018
RRS P400e 2017-2018
RRS P525 2018-2022
RR VOGUE 2022-2024
RR P550e 2024
Post #703027 25th Oct 2024 5:56am
Clipper
Great photo - thanks.
Post #703075 25th Oct 2024 5:43pm
