Home > Technical (L405) > pdc/park assit
Page 1 of 4 1234>
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
pdc/park assit
hi guys
new to the l405 (ex l322 owner) my park assist and parking sensors don't work ,i have no error codes using the gap tool ,so at the mo im a bit lost anybody point in a direction would be great
thanks will
Post #702725 20th Oct 2024 8:28pm
will308f
nobody ??????
Post #702771 21st Oct 2024 3:58pm
sorry, the 'park assist and parking sensors' expert is on holiday at the moment..
have you done a forum search? ... - .- -.
Post #702785 21st Oct 2024 5:36pm
will308f
Fingers crossed they will be back soon …..yea I did but not a lot about these problems ,what’s confusing is that there is no error codes reversing camera works as dose the kerb views just no front or rear parking sensors or park assist so weird
Post #702810 21st Oct 2024 9:32pm
have you tried manually switching on park assist?
the owners manual says that if theres a fault you will hear a high pitched note sounding...
also have a look in the workshop manual because i believe there's a troubleshooting section there..
and is there an on/off in the menus anywhere? ... - .- -.
Post #702821 22nd Oct 2024 8:52am
will308f
Thumbs Up do you what i wouldn’t be surprised if it was as simple as them been switched off as there is no error codes just the long tone and message saying to contact dealer
Post #702824 22nd Oct 2024 9:01am
will308f
right tried to enable pdc but no change ...can one faulty sensor stop them all working and if so wouldn't it show an error code using the gap tool ????
Post #702933 23rd Oct 2024 7:46pm
rryan
United Kingdom 2010 Range Rover Vogue TDV8 Buckingham Blue
This is me just thinking out loud as I had trouble with the sensors on an old BMW of mine. I had one faulty sensor which turned the whole system off. To determine the faulty sensor I manually turned them on via the button inside and, putting your ear close to each sensor outside, you could hear a faint clicking sound from the working ones. No feedback at all from the faulty one. Swapped this out and the system came to life.
I’m assuming the systems are completely different but I guess it’s an idea to try. 2009 facelift L322 3.6 TDV8 - Buckingham Blue
Post #702966 24th Oct 2024 9:00am
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
In a word, yes - one faulty sensor will cause both front and rear sensors to be disabled, a DTC should be logged and should identify the faulty sensor, wiring issue etc. When a fault is detected you get a 3 second low tone and the PDC switch led flashes 6 times and then the contact dealer message is displayed.
Have you checked with the GAP IID that you can communicate with the PDC ecu etc? Are you checking for just permanent codes only on the GAP tool, if so, try pending codes etc L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #702974 24th Oct 2024 10:02am
will308f
right ok thanks i’ll re-check with the gap tool fingers crossed it’s just a faulty sensor Thumbs Up
Post #703008 24th Oct 2024 6:50pm
will308f
Ok had a chance to look at this again,disconnected battery for a minute to clear everything re-scanned with gap tool and now showing these error codes
How ever all my cameras work so is it a sensor or a pdc control module?
Will
Post #703077 25th Oct 2024 6:06pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
maybe a coincidence, but 255 seems like an error (it's 8 x 1's in a 1 Byte register) Wondering if it's the module?
It may well just be that the maximum discernible distance is 2.55m... Formerly happymadison1978
Post #703189 27th Oct 2024 3:41pm
4RRS
I suppose the check would be walk around the car whilst monitoring the values and see if they change.
So, just checked my car, same spec, surround cameras and auto park and it does indeed default to a max of 2.55m but do change as something moves into the detection range.
HTH L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #703190 27th Oct 2024 3:52pm
will308f
yea not sure if 2.55 is the max distance of the sensors,but i’m thinking it is the module seen some for sale on ebay so may get one of them even just to rule it out
Post #703191 27th Oct 2024 4:02pm
4RRS
Do you get the error tone and message not available visit dealer or does all seem normal? L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #703192 27th Oct 2024 4:03pm
Page 1 of 4 1234>
