Home > My Range Rover > My 2012 Westminster TDV8 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7844 |
Looks cracking.
18th Oct 2024 7:07pm |
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 394 |
Hi,
18th Oct 2024 7:38pm |
RobsterPC Member Since: 14 Oct 2024 Location: Kent Posts: 115 |
Thanks both, I'll tackle that when I do the brakes. |
18th Oct 2024 7:44pm |
It’s here to be exact;
18th Oct 2024 7:50pm |
18th Oct 2024 8:53pm |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1434 |
Welcome looks very nice. many happy miles
18th Oct 2024 9:16pm |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 772 |
Congrats on the new Westie in the best colour! The red X is for turning off the screen, not for going back! Get yourself some decent tyres and that will make a big difference. If you're doing anything off road, General Grabber AT3's are a good choice. Lower front plastic trim is a common issue which I've lived with on two TDV8's. Lower boot cables can be easily replaced and worthwhile doing it before they corrode through and snap at an inopportune moment! Enjoy! |
19th Oct 2024 2:09am |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 354 |
Love it |
19th Oct 2024 3:17pm |
First maintenance today. After failing to start the other day it was time for a new battery.
23rd Oct 2024 5:31pm |
Swapped out the lower boot cables. Only rust on the washers, the car body itself is fine.
23rd Oct 2024 5:32pm |
Final job for the day, new pads. Fortunately I'd ordered replacement pins as one of the original ones did not want to be removed without a lot of persuasion. I ran out of time after doing one side, I'll do the other side tomorrow. The only issue is that Autodoc sent the wrong brake wear sensor cable so need to get the right one from somewhere tomorrow. I'll do the other side tomorrow.
23rd Oct 2024 5:35pm |
New wheel bolts. One of the old ones was beyond even a 23mm socket. A combination of 22.5 and 23mm was enough to get the old ones off and new ones on.
25th Oct 2024 3:49pm |
30th Oct 2024 6:34pm |
Gentle Giant Member Since: 01 Nov 2024 Location: East Neuk of Fife Posts: 16 |
Clever! |
1st Nov 2024 12:26pm |
