![]() | Home > My Range Rover > My 2012 Westminster TDV8 |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1285 ![]() ![]() ![]() |
Just out of interest, how depleted was the old seat base compared to the new? |
RobsterPC Member Since: 14 Oct 2024 Location: Kent Posts: 121 ![]() ![]() |
I couldn't see see much from looking at the size but it definitely feels more supportive. |
It was 10am by 15cm, loads on Amazon, mine was this one:
137,400 miles and with a trip to the Alps looming I thought it was time for an oil change, the last one was done at 131k miles. Armed with a 12v oil pump, 10l of 5w30 and a fresh filter I braved the cold and gave it a go.
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 645 ![]() ![]() ![]() |
Simple Tip:
Great tip, I'll try and remember to change that next time I do it |
Wiper blades now replaced front and rear. In the process I discovered my front drivers one wasn't locked in place after the last change. And that the aero deflector has been snapped. Time for a new one, if I can find it. Aside from that, easy job and less than 5 minutes to do, once I knew what I was doing |
Back from a 1,250 mile round trip to the Alps. The pre-trip work paid off and everything went smoothly, zero issues, fluids remained in the right place aside from fuel which avveraged 27.5mpg which wasn't bad for 4 blokes and a very full boot of kit. We hit over 80mpg on the way off the mountain |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 206 ![]() ![]() |
Great stuff. It looks good. 2012 Vogue TDV8 in Aintree green over sand |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8721 ![]() ![]() ![]() |
Vibration may be the pads imprinting on the discs after a long drive then sitting unused for a week. There is nothing that can't be fixed with a hammer๐๐
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 897 ![]() ![]() ![]() |
Possibly could also be an upper suspension arm ball joint - I have same sympton and need to change mine - they are about ยฃ12 quid each |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 961 ![]() ![]() |
Am watching with interest as I'm doing pretty much the same jobs on my 5.0 sc. So far
Good news, the vibration has gone so possibly what Northern Monkey said. For once the car hasn't created more expense!
Double post. |
