Home > Range Rover Classic > Sprayed my RRC with rattle cans!! |
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 217 |
I think you've done a pretty good job, certainly the effort cannot be faulted. I only did one rear quarter panel after some rust repairs and that came out well but the hardest thing to do with a rattle can is to get good clear coat. Did you use 2k clear in a rattle can?
7th Oct 2024 7:33pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1642 |
Cheers
7th Oct 2024 10:30pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3040 |
That's a good effort!
7th Oct 2024 10:45pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6406 |
A tip I found for spraying with cans is to use two at the same time, at right angles to each other. This gets more paint onto the surface in one pass for a "better" finish. This also works with clear coat.
8th Oct 2024 2:15pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8105 |
That looks great, seen so called professionals do a worse job... Pete
8th Oct 2024 4:59pm |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 356 |
Did you use a rattle can shaker? 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
10th Oct 2024 2:16pm |
Yes... my right arm!
13th Oct 2024 3:45pm |
