Home > Range Rover Classic > Sprayed my RRC with rattle cans!! |
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 394 |
I think you've done a pretty good job, certainly the effort cannot be faulted. I only did one rear quarter panel after some rust repairs and that came out well but the hardest thing to do with a rattle can is to get good clear coat. Did you use 2k clear in a rattle can?
7th Oct 2024 6:33pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 |
Cheers
7th Oct 2024 9:30pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3143 |
That's a good effort!
7th Oct 2024 9:45pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 |
A tip I found for spraying with cans is to use two at the same time, at right angles to each other. This gets more paint onto the surface in one pass for a "better" finish. This also works with clear coat.
8th Oct 2024 1:15pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8363 |
That looks great, seen so called professionals do a worse job... Pete
8th Oct 2024 3:59pm |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 372 |
Did you use a rattle can shaker? 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
10th Oct 2024 1:16pm |
Yes... my right arm!
13th Oct 2024 2:45pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1569 |
@Ajac8:
16th Oct 2024 7:17pm |
16th Oct 2024 9:48pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 |
Maybe buy a cheap HVLP system for next try? Would have cost less in paint I think? |
17th Oct 2024 12:24am |
Just had to google that to find out what CTC was referring too. Yes I see your point - perhaps next time.
17th Oct 2024 6:10pm |
Yes many many times. We have had a site spraying buisness in the family for many many years. We have sprayed hundreds of shop fronts, garages, window frames, steel staircases etc etc etc. All using HVLP systems.
17th Oct 2024 6:56pm |
