![]() | Home > Range Rover Classic > Sprayed my RRC with rattle cans!! |
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 400 ![]() ![]() ![]() |
I think you've done a pretty good job, certainly the effort cannot be faulted. I only did one rear quarter panel after some rust repairs and that came out well but the hardest thing to do with a rattle can is to get good clear coat. Did you use 2k clear in a rattle can?
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 ![]() ![]() ![]() |
Cheers
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3149 ![]() ![]() ![]() |
That's a good effort!
A tip I found for spraying with cans is to use two at the same time, at right angles to each other. This gets more paint onto the surface in one pass for a "better" finish. This also works with clear coat.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
That looks great, seen so called professionals do a worse job... |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 372 ![]() ![]() ![]() |
Did you use a rattle can shaker? 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Yes... my right arm! |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1595 ![]() ![]() ![]() |
@Ajac8:
Maybe buy a cheap HVLP system for next try? Would have cost less in paint I think? |
Just had to google that to find out what CTC was referring too. Yes I see your point - perhaps next time.
Yes many many times. We have had a site spraying buisness in the family for many many years. We have sprayed hundreds of shop fronts, garages, window frames, steel staircases etc etc etc. All using HVLP systems.
