![]() | Home > Technical (L405) > 3.0 TDV6 Crankshaft issue |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1162 ![]() ![]() ![]() |
20L for around £100 for a quality oil is not bad at all. |
ash83 Member Since: 21 Jul 2024 Location: NYC Posts: 32 ![]() ![]() |
There seems to be more failures on the SDV6 on Sports. I guess it could be the extra power, lot more torque than TDV6 |
1. IMO it’s highly unlikely for a C3 oil to mess up your DPF. It is designed for DPF’s. The SAPs difference from the C1 is small. Have you seen oil in these vehicles after use? It’s black. I’d be more concerned with the EGR valve dumping dirty exhaust fumes and Regens dumping fuel into the engine than a minuscule amount of sulphur. 2. 2016 and back have a DPF too…. There are tons of GREAT C3 oils and very few C4. If you do 5k mile intervals I wouldn’t worry using a C3. JMO. |
