Home > Technical (L405) > 3.0 TDV6 Crankshaft issue
Page 3 of 4 <1234>
cass
Shocked
That's both fascinating and worryingly convincing at the same time.
I didn't know I'd become that interested in crankshafts Laughing
Post #655756 5th Feb 2023 10:22pm
fisha
I found it interesting as well … The designers clearly had concerns about the design from the outset. Such a shame it would appear to have tarnished the reputation of the engine, as by all other accounts it’s a good unit and suited to the vehicles it goes in. V8 or else ...
Post #655822 6th Feb 2023 12:46pm
Kot
knwatkins wrote:
knwatkins wrote:
The main issue is down the fundamental design of the bottom end to support a transverse mounting arrangement for installation into the Citroën C5, Citroën C6 and Peugeot 407. This leaves the crank web or cheek to contain less mass than what would typically be present in a robust design.
Coincidentally, the following video has been posted by LR Time today. If you skip to around 16 minutes, this is discussed. Worth a watch if anyone is interested.
Great Video Thanks 2018 SE SDV8 4.4 Byron Blue
Post #655898 7th Feb 2023 10:18am
Delict
Slovakia
Mikey wrote:
JLR wanted the whole engine to be 2" longer due to concerns about the crank
PSA said no, as it then wouldn't fit the transverse cars. Being owned by Ford, JLR had no choice in the matter
Allegedly...
This post has been edited by the site administration team
PSA already had V6 transverse engine, and used it succesfully for years. 3.0i XFU, 211hp ES9J4S with no mechanical problems. There was even an tuning option from carlsson with 233hp.
Please take a look at the crankshaft part nr 0501.J2. The crankshaft is 4x seated in engine block.
The deal between FORD and PSA was this :: PSA gave reliable 1.6, 2.0 and 2.2HDi engines and got unreliable V6, because they never had any V6 diesel.
8
FORD made it by cutting the bigger AJD V8 diesel, just look at the crankshaft, its the same.
Its nice you want to blame PSA, but no, LR always had problematic engines. Starting with head cracking TD5 and ending with TDV/SDV6.
3.0 HDi ended with Peugeot 407 (2011) and Citroen C5 (2016), and they never exceeded 241hp and 450Nm.
Post #698799 25th Aug 2024 7:01am
Vogue
Well I’m on my 4th V8 Diesel - no issues whatsoever with the engine, no oil dilution and no DPF issues at all. We’ve also had several Discovery TD5’s from new - again no issues whatsoever. The only RR engine I have had issues with was the VM diesel fitted to the classics - again bought new and serviced by LR. Other members of the family have had failures with the V6 Diesel - again MD serviced. That’s my experience and I’m on my 17th RR. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #698838 25th Aug 2024 8:28pm
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
Having owned Landrovers in the past the VM diesel was my first experience of Range Rovers. I was told by my local Indie that they were basically a marine engine and the nearer to the sea bed the better. Seriously though it was a powerful and reasonably quiet engine, when it was running. When I got bored with pieces flying off it and constant challenges I replaced it with a 300 Tdi. Had 4 FFs since but I still look back with affection on the Tdi. 250k miles and never a broken crankshaft.🤔
Post #698845 26th Aug 2024 8:21am
ash83
United States
There’s a ton of reasons to change the oil at 5k miles/8k Km.
Fuel dilution (particularly from regens), abrasive soot/etc, oil shearing.
On the last point, I’d highly recommend a good C3 oil on these vehicles. Much more protective to bearings than what LR specs.
Post #700217 17th Sep 2024 5:16am
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
I am running 5W40 C3 oil in my TDV6 and changing every 6k miles / 6 months whichever occurs first. I know there are plenty or views on the 5W30 v 5W40 debate but after looking in detail at the argument that was my conclusion. The proof will be in the pudding as to whether my engine lasts longer, doesn’t suffer crank failure (although that is still not proof it was all due to the oil choice).
I think the main issue is that Ford ‘improved’ the crank when fitting it to their pickups in the US, so that tends to point to them acknowledging there was a design issue as opposed to a manufacturing issue. Ford also specified 5W40 for arduous use conditions.
Post #700219 17th Sep 2024 6:38am
chugga90
The tdv6 being used in the Volkswagen Amarok is still snapping cranks. So not enough to solve it!
Post #700220 17th Sep 2024 6:44am
cass
I'm curious, Why would any manufacturer recommend the "wrong" oil?
Post #700288 17th Sep 2024 6:37pm
Alex1976
It is not so much the ‘wrong oil’ but one that is designed to achieve fuel efficiency targets but potentially at the cost of engine longevity.
As mentioned previously, Ford recommend a 5W40 oil for arduous conditions or where bio diesel blends are used.
Post #700298 17th Sep 2024 8:00pm
ash83
United States
A few reasons.
The oil they specified is an older certification for one. C1 is going to be harder to find.
C1 is a bit less SAPS than a C3, so probably safer for DPF on LR’s ridiculously long OCI. Change it at 5k and a smidge extra SAPS shouldn’t matter.
Their long OCI is due to hitting ownership cost benchmarks. Marketing.
Post #700306 18th Sep 2024 4:59am
cass
That’s interesting and makes sense
Post #700319 18th Sep 2024 12:14pm
ash83
United States
and yes fuel economy is likely a reason too.
Post #700331 18th Sep 2024 2:42pm
Kot
Here's another one!
https://www.facebook.com/groups/6269149741...357124165/ 2018 SE SDV8 4.4 Byron Blue
Post #700733 23rd Sep 2024 2:39pm
Page 3 of 4 <1234>
