![]() | Home > Technical (L405) > 3.0 TDV6 Crankshaft issue |
SIMON1599 Member Since: 30 Jan 2022 Location: EAST YORKSHIRE Posts: 14 ![]() ![]() ![]() |
The TDV8 is not completely exempt from crank issues either!
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 760 ![]() ![]() |
"The TDV8 is not completely exempt from crank issues either!"
All cars, all engines can have issues. Nothing is fail proof.
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
The crank issue has not gone away. Still happing on disco 5s. |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1688 ![]() ![]() ![]() |
“ I wont take a chance on a TDV6”
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3788 ![]() ![]() |
There is a dealer / main agent note / TSB which Land Rover specifically published relating to the TDV6 Diesel failure issues - it’s been posted on this forum before - it may be worth a search to establish if there was any reference or relationship to specific VIN numbers. Doh - edited it’s in my gallery !
Well, I had to read my original post as I thought I asked a simple question but some folks seemed to think I was looking for buying advice or a comparison of the different engines available.
@Cass:
Not everyone has the time or know how that you seem to have to do almost all of the maintenance/ repairs themselves. Hence some people do succumb to said madness and/ or stupidity and spend hundreds/ thousands of pounds a year on a warranty. There is the other topic of JLR good will. Those who do use and can evidence use of the LR service/ maintenance network and an extended warranty probably have a stronger goodwill contribution case, even if something major goes wrong and is not covered by warranty. Perhaps less likelihood of goodwill if an owner can only evidence almost all of the maintenance/ repairs themselves. If you’ve read the forum posts deeply enough you’ll also see a well made point about those less common occasions where an L405 Tdv6 crankshaft failed… ie the owner not being left high and dry to pay for it by LR, the repair costs got covered. An open forum, so people will read posts, questions and replies before interpreting and replying to them in their own way. Sometimes we like the replies we get and sometimes we don’t. Suppose the main thing is restraint/ not inadvertently insulting others who might take a differing approach (“madness or stupidity”) ![]() |
@PLD118:
[quote="Gremlin500"]@Cass:
Completely agree which is why I don't reply to posts with a now deleted yawn Emoji ![]() |
Your words. ![]() ![]() ![]() |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 774 ![]() ![]() ![]() |
My gosh, the tone and tittletattling on this forum certainly changes when the TDV6 crank subject comes up
Correct. The main issue is down the fundamental design of the bottom end to support a transverse mounting arrangement for installation into the Citroën C5, Citroën C6 and Peugeot 407. This leaves the crank web or cheek to contain less mass than what would typically be present in a robust design. Of course, those who have purchased TDV6 engined vehicles will naturally try and defend their purchase. I did exactly this before I experienced a bottom end failure myself (to be clear, I'm talking about the car ![]() Being an engineer I have a significant number of technical reports on this very subject. For those who are technically minded, here's one of my favourites to substantiate the design methodology and engineering of the TDV6 when it was in the 2.7 form: https://drive.google.com/file/d/1S7O_dmPFq...sp=sharing Interestingly, I find section 4.1 of the report quite ironic... "For V6 automotive engines crankshaft durability is usually the most vulnerable at the big end bearing fillets of the flying webs. This is due to significant combustion generated bending moments that act across the big end bearing overlap section coupled with large stress concentrations at the small radius fillets." Anyway, enough of this off topic nonsense, to answer your original question directly....
No, it has not been resolved. The fundamental design of the engine is the same. Kev 2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey 2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
