Home > Technical (L405) > Drone at speed |
evotime Member Since: 02 Apr 2021 Location: Aberdeenshire Posts: 131 |
Likely a diff starting to become noisy. might stay like that for years. Had very similar on my Sprinter. Started with a very slight drone under power (could hear something in the background) but quiet when power was removed. It got real noisy in around 600 miles to the point I limped home, even then, quiet with no load but crazy loud when I touched the throttle.
24th Sep 2024 5:41pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3136 |
check exterior trims - could be A pillar or front scuttle? or heat shield under car? |
25th Sep 2024 8:47am |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2575 |
What are the revs at this point? Mine does it at circa 1300/1500 revs (under load only) and is the exhaust heat shield 2013 L405 Autobiography Baltic Blue
25th Sep 2024 11:10am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2637 |
Used to get this all the time , until her indoors stopped talking
25th Sep 2024 12:21pm |
