Home > Technical (L322) > ACC retrofit to MY12 4.4 TDV8 help |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2541 |
No the bumper is the same with or without the radar unit. My radar unit has gone faulty after working for 8 years. |
21st Sep 2024 6:08am |
loudog3114 Member Since: 26 Jul 2024 Location: Plymouth MA Posts: 26 |
How did you know? Codes? |
21st Sep 2024 12:05pm |
Just check for faults and I have this. Any idea what this means?
21st Sep 2024 12:14pm |
Maybe re-check your CCF parameters. If you've enabled stop&go then try with that feature disabled.
22nd Sep 2024 3:05am |
Tried both combinations unfortunately. I'm wondering if my vin is close enough to the older vin that it needs the ACC module in the trunk? It's BA35*** |
22nd Sep 2024 4:31am |
You acquired switch LR023197. My investigations revealed that the switch part number for BA349700+ the switch part number is LR029644. I don't know if that is due to a change in operation or just a superficial reason such as a new colour or style.
22nd Sep 2024 9:43am |
I actually ultimately ended up with switch LR057123 after lots of back and forth with Scudaria. |
22nd Sep 2024 2:27pm |
I see that my number has been superseded by your number, so the switch isn't an issue. |
22nd Sep 2024 8:52pm |
Pat shot me an email back and he thinks the lack of input shouldn't be an issue, but I can't get past the blinking ACC light. I wonder if because my vin is so close to BA3 that may be it still needs the rear acc module? |
22nd Sep 2024 9:00pm |
Microcat 2012 shows the 5.0 NA and SC having both a 2nd radar unit and the adaptive speed controller in the rear, with no end to the VIN range. However IIRC earlier in this thread at least one 5.0 owner only had to install a single radar unit and no rear controller, so Microcat 2012 must not be telling the whole story. The rear controller changed part numbers from VIN BA334343 but the earlier number supersedes to the later number anyway. |
23rd Sep 2024 5:58am |
I must need the rear acc module. Got a part number for my vin?
23rd Sep 2024 6:50am |
The part number is LR025949 whereas I understand that the other number is a production/assembly code.
23rd Sep 2024 7:50am |
No connector unfortunately
23rd Sep 2024 1:47pm |
I couldn't find anything in the wiring diagrams including the HS canbus diagram for it either.
23rd Sep 2024 8:48pm |
