Home > Technical (L322) > ACC retrofit to MY12 4.4 TDV8 help |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2390 |
No the bumper is the same with or without the radar unit. My radar unit has gone faulty after working for 8 years. |
21st Sep 2024 7:08am |
loudog3114 Member Since: 26 Jul 2024 Location: Plymouth MA Posts: 14 |
How did you know? Codes? |
21st Sep 2024 1:05pm |
Just check for faults and I have this. Any idea what this means?
21st Sep 2024 1:14pm |
Maybe re-check your CCF parameters. If you've enabled stop&go then try with that feature disabled.
22nd Sep 2024 4:05am |
Tried both combinations unfortunately. I'm wondering if my vin is close enough to the older vin that it needs the ACC module in the trunk? It's BA35*** |
22nd Sep 2024 5:31am |
You acquired switch LR023197. My investigations revealed that the switch part number for BA349700+ the switch part number is LR029644. I don't know if that is due to a change in operation or just a superficial reason such as a new colour or style.
22nd Sep 2024 10:43am |
I actually ultimately ended up with switch LR057123 after lots of back and forth with Scudaria. |
22nd Sep 2024 3:27pm |
