Home > Technical (L322) > ACC retrofit to MY12 4.4 TDV8 help
Page 14 of 14 <123 ... 121314
loudog3114
United States
Well that's not inspiring. Do we think the ACC range got a different bumper? I've had a lot of ACC vehicles and none of them have ever had the radar unit blocked by the bumper.
Post #700541 21st Sep 2024 4:05am
GraemeS
No the bumper is the same with or without the radar unit. My radar unit has gone faulty after working for 8 years.
Post #700542 21st Sep 2024 7:08am
loudog3114
United States
How did you know? Codes?
Post #700577 21st Sep 2024 1:05pm
loudog3114
United States
Just check for faults and I have this. Any idea what this means?
My vin is BA35** so I'm assuming I don't need anything but the radar module and the steering switches which I have installed. Thought this may be helpful. Also sent to gap.
This is the radar module I installed.
Post #700578 21st Sep 2024 1:14pm
GraemeS
Maybe re-check your CCF parameters. If you've enabled stop&go then try with that feature disabled.
Mine showed radar unit blocked shortly after every start-up which indicates that it isn't seeing a reflected beam. This could be caused if the unit is so misaligned that the reflected beam isn't seen, but it isn't misaligned, or that the transmitter or receiver has failed. I don't have access to a monitor for 77 GHz signals so I can't check if the transmitter is working, not that I'm likely to be able to repair it.
Post #700611 22nd Sep 2024 4:05am
loudog3114
United States
Tried both combinations unfortunately. I'm wondering if my vin is close enough to the older vin that it needs the ACC module in the trunk? It's BA35***
Post #700612 22nd Sep 2024 5:31am
GraemeS
You acquired switch LR023197. My investigations revealed that the switch part number for BA349700+ the switch part number is LR029644. I don't know if that is due to a change in operation or just a superficial reason such as a new colour or style.
What prompted you to get that part number?
Post #700631 22nd Sep 2024 10:43am
loudog3114
United States
I actually ultimately ended up with switch LR057123 after lots of back and forth with Scudaria.
Post #700648 22nd Sep 2024 3:27pm
