Home > Technical (L322) > Front parking sensors
kevinp
Does anyone know if it is possible to turn the front parking sensors on permanently, possibly with the IID tool?
My wifes Jeep does it and I do find it handy in tight spaces.
Post #700255 17th Sep 2024 11:32am
You can't.
The fronts will only be activated after the rears have been. ... - .- -.
Post #700307 18th Sep 2024 6:36am
GraemeS
Pressing the button will activate the front sensors. I'd like to get accustomed to doing this while getting into tight spaces, but never think of it in time.
Post #700312 18th Sep 2024 10:12am
kevinp
I do press the button but it would be nice if it was always active. Thumbs Up
Post #700316 18th Sep 2024 11:25am
Dutchgit
Germany 2008 Range Rover Vogue TDV8 Stornoway Grey
You possibly could do that by wiring in a momentary relay to the 'sensor on' switch which is fed from the ignition or maybe even better, the wire that tells the car to start.
Some electric guru will know exaclty how. Rolling Eyes
Post #700412 19th Sep 2024 5:04pm
GraemeS
Do they stay on after reversing when they normally switch off once a particular speed is attained?
Post #700431 19th Sep 2024 8:54pm
kevinp
They do stay on after reversing but I don't know what the parameters are for them switching off.
Post #700442 19th Sep 2024 11:23pm
GraemeS
This morning's test revealed that they switch off after a particular speed and also if the gearbox is put into park. Hence auto switching on when starting the engine would be futile.
Post #700444 20th Sep 2024 12:57am
kevinp
Post #700458 20th Sep 2024 8:38am
