![]() | Home > Technical (L322) > Front parking sensors |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35489 ![]() ![]() |
You can't.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2567 ![]() ![]() ![]() |
Pressing the button will activate the front sensors. I'd like to get accustomed to doing this while getting into tight spaces, but never think of it in time. |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1271 ![]() ![]() ![]() |
I do press the button but it would be nice if it was always active. |
Dutchgit Member Since: 17 Sep 2023 Location: Emmerich am Rhein Posts: 178 ![]() ![]() ![]() |
You possibly could do that by wiring in a momentary relay to the 'sensor on' switch which is fed from the ignition or maybe even better, the wire that tells the car to start.
Do they stay on after reversing when they normally switch off once a particular speed is attained? |
They do stay on after reversing but I don't know what the parameters are for them switching off. |
This morning's test revealed that they switch off after a particular speed and also if the gearbox is put into park. Hence auto switching on when starting the engine would be futile. |
