Home > Technical (L322) > Front parking sensors |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35264 |
You can't.
18th Sep 2024 6:36am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
Pressing the button will activate the front sensors. I'd like to get accustomed to doing this while getting into tight spaces, but never think of it in time. |
18th Sep 2024 10:12am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1205 |
I do press the button but it would be nice if it was always active. |
18th Sep 2024 11:25am |
Dutchgit Member Since: 17 Sep 2023 Location: Emmerich am Rhein Posts: 178 |
You possibly could do that by wiring in a momentary relay to the 'sensor on' switch which is fed from the ignition or maybe even better, the wire that tells the car to start.
19th Sep 2024 5:04pm |
Do they stay on after reversing when they normally switch off once a particular speed is attained? |
19th Sep 2024 8:54pm |
They do stay on after reversing but I don't know what the parameters are for them switching off. |
19th Sep 2024 11:23pm |
This morning's test revealed that they switch off after a particular speed and also if the gearbox is put into park. Hence auto switching on when starting the engine would be futile. |
20th Sep 2024 12:57am |
20th Sep 2024 8:38am |
