Home > Technical (L322) > Heater fan out of control!!!!!! |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 43 |
It sounds typically like a failing final stage resistor or FSR. look in the wiki on this website,and there is a good write up re dealing with the problem. It is listed at the bottom of the section headed heating and cooling. |
17th Sep 2024 7:04pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 789 |
+1 FSR |
17th Sep 2024 7:09pm |
Happydaze Member Since: 30 Aug 2021 Location: Wirral Posts: 55 |
Will do! Thankyou gentlemen!
17th Sep 2024 8:58pm |
madnessgonemad Member Since: 28 Aug 2020 Location: Kent Posts: 90 |
Quite easy to replace it. Just a bit fiddly.
18th Sep 2024 10:59am |
Id already ordered one from PowerfulUK at £35. A little on the expensive side compared to many on ebay for very possibly the same stuff but I've found their videos to be of great use so I've always thought they're worth supporting over and above a box shifter.
19th Sep 2024 9:34am |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 778 |
The only difficulty with replacing the FSR ( aka the hedgehog ) is the off tilt angle that it comes out on, and the off tilt angle it goes back in, once under there you will see what I mean, you can feel your way to remove it, just make a mental note of the angle it came out, so that when you push the new one back in place the angle is remembered. |
19th Sep 2024 10:21am |
The postman did his thing yesterday and I got straight on it. Before attempting to install the new unit I gave the location a darned good familiarisation which helped enormously when fitting the unit. Slotted straight in. I had a struggle for a short while orientating the electrical connection but it clicked into place and a quick test proved all to be well.
20th Sep 2024 11:30am |
