Home > Technical (L322) > Heater fan out of control!!!!!!
Happydaze
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
2007tdv8.
I've searched the forums but couldn't find anything like this problem, so any help appreciated.
Moderately warm September day today. Came to start the car and found the heater blower blowing like crazy. It's uncontrollable on the dial and even runs ( moderate speed) when switched off, key out and vehicle vacated. It just keeps running. Disconnected the battery and it stops. Reconnected 30 mins later and its back on.
I'm not sure what controls the heater / fan motor, but suspect it must be that.
Any pointers very much appreciated!
Chris
Post #700284 17th Sep 2024 6:54pm
Dtech
England 2011 Range Rover Vogue 4.4 V8 Santorini Black
It sounds typically like a failing final stage resistor or FSR. look in the wiki on this website,and there is a good write up re dealing with the problem. It is listed at the bottom of the section headed heating and cooling.
Post #700286 17th Sep 2024 7:04pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
+1 FSR
Post #700287 17th Sep 2024 7:09pm
Happydaze
Will do! Thankyou gentlemen!
I saw references to fsr and thought wtf???? And some other acronyms I think to do with fuel heaters.
Anyway, off to the fsr wiki!
Chris
Post #700297 17th Sep 2024 8:58pm
madnessgonemad
Quite easy to replace it. Just a bit fiddly.
I suggest you don’t buy a very cheap replacement as they are not very good and you will have to do it again soon after!
Powerful UK sell them
Post #700311 18th Sep 2024 10:59am
Happydaze
Id already ordered one from PowerfulUK at £35. A little on the expensive side compared to many on ebay for very possibly the same stuff but I've found their videos to be of great use so I've always thought they're worth supporting over and above a box shifter.
It's due here tomorrow and in preparation I removed the existing unit yesterday without much difficulty.
PowerfulUK's guidance on this is to leave the electrical connection until the unit is released as this helps in getting the unit free and when free the clips on the electrical plug are easily accessible, which is not the case otherwise, so good, helpful advice!
Hopefully the fumbling around in the dark awkward space won't be too taxing on the installation. Time will tell!! C'mon Mr Postman!
Chris
Post #700376 19th Sep 2024 9:34am
pcourtney
The only difficulty with replacing the FSR ( aka the hedgehog ) is the off tilt angle that it comes out on, and the off tilt angle it goes back in, once under there you will see what I mean, you can feel your way to remove it, just make a mental note of the angle it came out, so that when you push the new one back in place the angle is remembered.
Post #700384 19th Sep 2024 10:21am
Happydaze
The postman did his thing yesterday and I got straight on it. Before attempting to install the new unit I gave the location a darned good familiarisation which helped enormously when fitting the unit. Slotted straight in. I had a struggle for a short while orientating the electrical connection but it clicked into place and a quick test proved all to be well.
Thanks for all comments and advise! Now need to move on to the replacement of the outer cv boot that got damaged when I was replacing the strut following an airbag failure. Some guys have all the fun!
Chris
Post #700469 20th Sep 2024 11:30am
