Home > Technical (L322) > Vibration / Resonance |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2384 |
Mine had a vibration/drone that seemed to be eminating from under the driver's floor which was found to be caused by 2 brake pipes near the master cyclinder vibrating together. A spacer clip had become detatched from 1 pipe. |
12th Sep 2024 9:51pm |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 43 |
Mine used to make a similar sound at about the same rpm and speed as yours. My wife used to say it sounded like a cow going moo. It turned out to be the transmission under tray resonating. |
12th Sep 2024 10:18pm |
CharlieF322 Member Since: 19 Mar 2024 Location: Essex Posts: 14 |
Thanks both! My transmission tray isn’t loose but I may take it off to eliminate and check the brake pipes. It does sound a bit “moo” now you mention it as it changes pitch as you bring the RPM up.
12th Sep 2024 10:23pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3051 |
The gearbox undersheild makes a noise but mine at least wasn't felt through the floor, didn't change pitch and I could only hear it with the window down. 2012 TDV8 Vogue (L322) |
13th Sep 2024 8:08am |
The brake pipes are close to the master cylinder/booster, seen from the top. |
13th Sep 2024 8:31am |
So I’ve been under the car, bonnet, wiggled anything that might rattle.
13th Sep 2024 5:01pm |
