Home > Technical (L322) > Vibration / Resonance |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2489 |
Mine had a vibration/drone that seemed to be eminating from under the driver's floor which was found to be caused by 2 brake pipes near the master cyclinder vibrating together. A spacer clip had become detatched from 1 pipe. |
12th Sep 2024 8:51pm |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 52 |
Mine used to make a similar sound at about the same rpm and speed as yours. My wife used to say it sounded like a cow going moo. It turned out to be the transmission under tray resonating. |
12th Sep 2024 9:18pm |
CharlieF322 Member Since: 19 Mar 2024 Location: Essex Posts: 16 |
Thanks both! My transmission tray isn’t loose but I may take it off to eliminate and check the brake pipes. It does sound a bit “moo” now you mention it as it changes pitch as you bring the RPM up.
12th Sep 2024 9:23pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3249 |
The gearbox undersheild makes a noise but mine at least wasn't felt through the floor, didn't change pitch and I could only hear it with the window down. 2012 TDV8 Vogue (L322) |
13th Sep 2024 7:08am |
The brake pipes are close to the master cylinder/booster, seen from the top. |
13th Sep 2024 7:31am |
So I’ve been under the car, bonnet, wiggled anything that might rattle.
13th Sep 2024 4:01pm |
Benji1 Member Since: 11 Sep 2023 Location: Perth Posts: 22 |
I have similar in my 2011 4.4 TDV8. In my case it only appears within the speed range of 70 to 90k and then goes away at higher speed. I have put this down to the rear tyres which in my case involves different brands front and rear. Its annoying however given a fair amount of rubber left on the rears think I will live with it until the next tyre replace. |
29th Sep 2024 11:00pm |
Yeah mines definitely not tyres
30th Sep 2024 10:30am |
I have to regularly clean out dried mud from the gearbox mount bracket. I've drilled a few 25mm drain holes trying to prevent mud accumulating but it still builds-up. I need to clean it out again now as the vibration is back again. |
30th Sep 2024 12:23pm |
