![]() | Home > Technical (L322) > ACC retrofit to MY12 4.4 TDV8 help |
loudog3114 Member Since: 26 Jul 2024 Location: Plymouth MA Posts: 26 ![]() ![]() |
Going to give it a go on my 11 5.0 HSE... |
Appreciate this and working on the same thing now. I am a BA vehicle but its BA35* so it should be the thin type sensor (which of course double the price). Did you end up getting it all working on yours? |
I pulled the trigger on parts.
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 415 ![]() ![]() ![]() |
finally got the proper bracket and fitted
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2566 ![]() ![]() ![]() |
Mine has had the radar unit blocked message for a while and still shows even after removing the bumper to check that it was clean. Its been set to recalibrate but I'm not hopeful that it will, suspecting that the radar unit has failed. I'll give it a few outings before reverting to standard CC.
Doing this piece mail as parts come in. Installed just the radar unit tonight and the wiring was there for it. Now getting a cruise control unavailable error in the car. I don't have the switch pack for the adaptive cruise control buttons yet... I'm guessing this is because the radar is installed but not coded yet? Think I could code it without the acc switches and have acc without the distance controls? |
Remove the radar unit's fuse until the CCF is configured for ACC then try again while waiting for the distance switches. |
Will do - waiting for a good deal on an IIDTOOL. I wont miss cruise in the mean time. |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 282 ![]() ![]() ![]() |
I have a set of adaptive cruise buttons….. U.K. spec. I see you’re in the US. I could list them on eBay if you’re interested and ship with the international shipping facility.
PM me if interested. TDV8 4.4 2012 |
Does US vs UK spec matter? I'm US LHD. |
I've added all the hardware and made all the changes from the first two pages. I now have the forward collision unavailable error on start and the flashing calibration light. Not sure if that means it's calibrating or if I need to kick off the calibration?
Mine initially calibrated when driving slowly between 2 high steel gates. |
How did you kick it off? Engine on and execute the calibration then drive? |
I don't recall but your flashing indicator suggests that it just needs to see suitable reflections.
