Home > Technical (L322) > ACC retrofit to MY12 4.4 TDV8 help
Page 12 of 15 <123 ... 1112 131415>
GraemeS
Australia
I don't recall the specific code but mine gave at least a similar code / message when the radar unit was powered but before the CCF had been fully changed to support ACC. Removing the radar unit's fuse stopped the code being logged so that's easy to test.
Post #671863 23rd Aug 2023 10:02pm
mgrover
I guess the question is how do I get the extra menu? Is it via emailing gap? Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #671878 24th Aug 2023 6:42am
RichTD6
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Yes, you need to email Pat at Gap Diagnostics and request the extra functions if you haven’t got them. He usually responds very quickly in my experience. He will probably make you aware that you should not modify any of the critical vehicle safety features as the full access gives you the ability to change almost everything in the CCF.
Rich 2012 Westminster TDV8 4.4 Indus Silver
GAP IID Bluetooth Tool
Previous Range Rovers:
2005 L322 Vogue SE TD6 Zambezi Silver
1995 P38A HSE Epsom Green
1988 Classic Vogue EFi Cassis Red
1973 Two Door Tuscan Blue
Post #671895 24th Aug 2023 9:03am
mgrover
That did the trick,
enabling. "Adaptive speed control indication in instrument cluster"
gave me the lovely flashing light which I guess means I need to go for a drive calibrate it.
I'll mess around with the other options once its calibrated.
Or will that reset the calibration?
ie enabling the stop/go, Collision mitigation by braking, Forward collision warning. Its actually a sport Sad
Post #671910 24th Aug 2023 11:53am
RichTD6
I think you will need to set all the settings before trying to use it as the collision mitigation is what it needs to apply the brakes if you catch up another car. I calibrated mine once all settings were made. For some reason, mine wouldn’t accept the collision mitigation Gen 1 option and always defaulted to Gen 2 when I saved the settings but it all works absolutely fine. You will also be able to enable/disable the forward assist warning, if you want it, by using the normal dashboard menu using the right hand steering wheel menu controls.
Post #671930 24th Aug 2023 4:20pm
mgrover
Ah ive driven around for a while and it didn't calibrate so probs why Its actually a sport Sad
Post #671931 24th Aug 2023 4:22pm
mgrover
A bit of an update.
I did try this bracket.
https://parts.jaguarlandroverclassic.com/l...nting.html
With some hammering and drilling it was in.
https://photos.app.goo.gl/W8mmdfjAhrumgYC8A
Not perfect by any stretch but it was in.
It never calibrated and eventually I got a Radar Sensor Blocked code.
Am sure I can faff and maneuver to try to make it work, but am just ordering the correct bracket.
But was worth a £30 punt if it had worked. Its actually a sport Sad
Post #673675 18th Sep 2023 11:05am
Bristol RR
United Kingdom 2012 Range Rover Westminster 4.4 V8 Ipanema Sand
Is there a definitive post that outlines what’s needed for this or a case of pulling it together from the previous pages I’m this thread?
Fine either way and if the latter will try to pull a summary together if it doesn’t exist.
Post #673732 18th Sep 2023 7:49pm
mgrover
its all in this thread.
but basically most people need
GAP Tool(with fully unlocked CCF, gotta email GAP) or a way to modify the full CCF
Cable
Sensor
Bracket Its actually a sport Sad
Post #673762 19th Sep 2023 8:40am
Bristol RR
Thanks will go through it and work out what’s needed inc parts and IID tool updates and settings.
I’ll try and do a write up and summarise the entire thing too.
Post #673790 19th Sep 2023 1:38pm
(Bmw)Wizard
Canada 2010 Range Rover Supercharged 5.0 SC V8 Alaska White
ACC control units found on ebay during my search for parts.
I found a seller in the USA that has lots of these Adaptive cruise control units as New/ old stock and seems to have sold quite a few. I have purchased one myself as I with to enable this feature on my 2010 FFRR. The modules seem to be at a very attractive price.
I hope this helps some owners on here. https://www.ebay.com/itm/160834633455
Post #683987 26th Jan 2024 5:51pm
(Bmw)Wizard
I found a youtube video of an owner in the EU that carried out the retrofit/conversion. You need to enable closed captions to understand what he says though.
It seems that all the wiring is there on some models.
I hope this helps:
Post #683989 26th Jan 2024 5:56pm
Notbostrom
United States 2004 Range Rover SE 4.4 V8 Barolo Black
Anyone tried this with a us spec RR?
Post #692935 19th May 2024 1:33am
(Bmw)Wizard
I have the switches and the module. I am just trying to find a good used radar at a a reasonable price. Only the later years work on ours.
Post #692936 19th May 2024 3:38am
Notbostrom
Maybe a naive question but with this system activated, does it have any automatic emergency braking functions in addition to the cruise control? Ie driving with cruise off?
Post #693025 20th May 2024 2:52pm
