Home > Maintenance & Mods (L322) > Water ingress through sun roof
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Just noticed some water staining and mould on the passenger side roof in between the sun roof and passenger door, and also around the top of the air bag on the forward left pillar
Have folk experienced any ingress / leaks from the sun roof?
Any obvious / easy remedies ?
Post #698328 18th Aug 2024 6:03pm
JayGee
On any car sunroof leaks are usually caused by blocked drains. It’s quite hard to make a moving sunroof 100% watertight so leakage is dealt with by a drainage system but when this gets blocked it will overflow into the headlining. 2012 TDV8 Vogue (L322)
Post #698334 18th Aug 2024 6:22pm
GrandadRob
England 2013 Range Rover Vogue SE SDV8 Luxor
I had this problem on a lovely D3. I eventually sold it because I could'nt cure it. However, I have never heard of this on a Range Rover.
But here is the method for clearing the drains.
Get some of that wire that your Lady uses to hang net curtains, the wire covered with white plastic.
Open the sunroof, there are probably four drains, one in each corner. Pass the wire down each tube, but do not use force, you may force pipe joins apart. I then used some warm water and washing up liquid to see if it poured out the bottom. Use small amounts of water.......and maybe a tube.
On the D3 each drain was clear, but it still occasionally leaked down the inside of the screen. 2013 SDV8 4.4 SE Luxor.
1960 Series 2 88 inch diesel.
1955 Series 1 86 inch petrol.
Post #698395 19th Aug 2024 2:11pm
Rambles
Thank you
Front drain holes easy to find, and they are clear
Rear drain holes i didn’t locate
BUT
I noticed in the middle of the back of the glass, the plastic strip / trim has split. Not sure if this will have created the leak, but a small piece of silicon wont hurt for now
Do folks know if this strip is replaceable, or does a new strip only come ready attached to a new sun roof glass?
Post #698440 20th Aug 2024 9:09am
Rambles
Actually I think it is not a split…it’s just the join of the edging !
But was peeling back….
And i think makes no difference
Post #698446 20th Aug 2024 11:37am
GrandadRob
Pop a little superglue on the join just in case. 2013 SDV8 4.4 SE Luxor.
Post #698449 20th Aug 2024 11:44am
Rambles
Thanks
On the FullFat…are you sure there are 4 drain holes?
The front 2 were easy access…no blockage…
And easy to see / feel when sun roof is back
I can’t see the rears
And cannot get my fingers / wire round the back when the sun roof is back
If front 2 are clear, is there any reason rear 2 would not be ?
Post #698465 20th Aug 2024 2:45pm
GrandadRob
Sorry if I confused you. I had 4 holes in the D3, presumed there would be same in RR. Same sized roof panel. The rear ones on the D3 were difficult to locate. 2013 SDV8 4.4 SE Luxor.
Post #698466 20th Aug 2024 2:52pm
Rambles
Found this thread !
https://www.fullfatrr.com/forum/post509715.html
You have been very helpful
Thank you
Post #698467 20th Aug 2024 2:55pm
Rambles
Grandad
Thank you
There are indeed 4 holes
I used a 500ml syringe..with a 15cm tube diameter 5mm to insert into the holes
Warm soapy water
If you slide the tube parallel to the aluminium rail (parallel to the length / side of the car) all the way to the rear of the chassis that holds the sun roof…it will go out of sight…the tube self locates into the drain holes.
A few of these into each of the 4 drains, and now each one flows freely
Funnily enough, despite my earlier assertation the front ones were clear, the front left took 4 full syringes before it flowed freely
Post #698468 20th Aug 2024 3:22pm
GrandadRob
Hey, that's great, must check mine Thumbs Up 2013 SDV8 4.4 SE Luxor.
Post #698469 20th Aug 2024 3:24pm
