![]() | Home > Maintenance & Mods (L322) > Water ingress through sun roof |
On any car sunroof leaks are usually caused by blocked drains. It’s quite hard to make a moving sunroof 100% watertight so leakage is dealt with by a drainage system but when this gets blocked it will overflow into the headlining. 2012 TDV8 Vogue (L322) |
GrandadRob Member Since: 01 Jul 2021 Location: North Herefordshire Posts: 227 ![]() ![]() ![]() |
I had this problem on a lovely D3. I eventually sold it because I could'nt cure it. However, I have never heard of this on a Range Rover.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 811 ![]() ![]() |
Thank you
Actually I think it is not a split…it’s just the join of the edging !
Pop a little superglue on the join just in case. 2013 SDV8 4.4 SE Luxor.
Thanks
Sorry if I confused you. I had 4 holes in the D3, presumed there would be same in RR. Same sized roof panel. The rear ones on the D3 were difficult to locate. 2013 SDV8 4.4 SE Luxor.
Found this thread !
Grandad
Hey, that's great, must check mine |
