Home > Maintenance & Mods (L322) > Water ingress through sun roof |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3235 |
On any car sunroof leaks are usually caused by blocked drains. It’s quite hard to make a moving sunroof 100% watertight so leakage is dealt with by a drainage system but when this gets blocked it will overflow into the headlining. 2012 TDV8 Vogue (L322) |
18th Aug 2024 6:22pm |
GrandadRob Member Since: 01 Jul 2021 Location: North Herefordshire Posts: 223 |
I had this problem on a lovely D3. I eventually sold it because I could'nt cure it. However, I have never heard of this on a Range Rover.
19th Aug 2024 2:11pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 803 |
Thank you
20th Aug 2024 9:09am |
Actually I think it is not a split…it’s just the join of the edging !
20th Aug 2024 11:37am |
Pop a little superglue on the join just in case. 2013 SDV8 4.4 SE Luxor.
20th Aug 2024 11:44am |
Thanks
20th Aug 2024 2:45pm |
Sorry if I confused you. I had 4 holes in the D3, presumed there would be same in RR. Same sized roof panel. The rear ones on the D3 were difficult to locate. 2013 SDV8 4.4 SE Luxor.
20th Aug 2024 2:52pm |
Found this thread !
20th Aug 2024 2:55pm |
Grandad
20th Aug 2024 3:22pm |
Hey, that's great, must check mine 2013 SDV8 4.4 SE Luxor.
20th Aug 2024 3:24pm |
