Home > Maintenance & Mods (L322) > Battery Replacement 2011 TDV8 4.4
Page 8 of 8 <12345678
pcourtney
spot on - thanks to OP Smile
Pass to the next person - the TS30 bit - happy to start off a new thread - thank you forum !
https://www.fullfatrr.com/forum/topic70889.html
Post #697108 29th Jul 2024 9:21pm
ditchvisitor
Was super useful when replacing mine, I’m normally pretty handy with the spanner’s and on initial inspection it did stump me somewhat!
Post #697679 9th Aug 2024 8:25am
RobsterPC
Quick note from when I did mine, I didn't undo the security bolts, I simply undid the plastic clips that retain the ECU cable and then, after undoing the single 10mm nut, was able to fold the ECU out of the way safely. No need for special pentalobe bits etc.
Post #703558 1st Nov 2024 12:52pm
pcourtney
I have replaced both those pesky TS25 bolts with simple 10mm bolts ( both for me and future owners of my car )
Post #703560 1st Nov 2024 12:55pm
LukeKnott
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
Re: Battery Replacement 2011 TDV8 4.4
Hi guys,
Does anyone have a part number or know where you can find one of the plates for the ecu bracket? (The one bolted on with the 2 security torx).Miine seems to have been removed at some point in it’s life, never to make it back on.
Post #705222 23rd Nov 2024 12:41pm
JayGee
Do you actualy need one? I took mine off when I replaced my battery 3 years ago and didn't see the point in putting it back on. 2012 TDV8 Vogue (L322)
Post #705307 24th Nov 2024 9:38am
LukeKnott
Just nice to have all the pieces of the puzzle! I think it just gives the ecu a bit of support at the top, rather than just hanging off the one nut at the bottom.You up for parting ways with yours?😂
Post #705365 24th Nov 2024 7:35pm
CaifanSC
United States 2012 Range Rover Autobiography 5.0 SC V8 Epsom Green
Does anyone have the part number for the thin plastic strap that attaches the orange cap for the positive battery terminal to the alternator cable? My orange cap has seen better days, I bought the cap but I can't find the PN for the black thin strap. I have a feeling that's going to break once I start fiddling with the battery. 2012 Range Rover Autobiography
91 BMW 850i 6 speed
94 BMW 850 CSi 6speed
Supercharged Tbirds
Audi S8, Audi V8 Quattro
Post #706126 5th Dec 2024 1:49am
MilesBFree
United States
Thanks everyone for all the info and tips above. - made changing my battery a breeze!
I thought I had the 5-point torx security bit but mine was the 6-point security one, so I managed to remove the screw with vice grips. Otherwise the whole thing was simple
Post #707397 22nd Dec 2024 4:28am
