![]() | Home > Technical (L322) > Bad Oil Leak and Oil Filter Housing Block Assembly |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1266 ![]() ![]() ![]() |
Is it actually leaking oil or is it just using oil? |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 852 ![]() ![]() ![]() |
I have some drops on the driveway, and the smell of oil in the cabin when I pull up to traffic lights etc
Have you done an oil change recently?
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 215 ![]() ![]() ![]() |
Did you replace the oil cooler itself when you did the gasket and 'O' rings? They have a tendency to warp or even crack so replacing the gasket and 'O' rings alone might not fix a leak? _______________________________________________
Defo check the oil fiter drain off valve and even if it's not off it's locating post the rubber goes hard and stops sealing properly. I removed mine and sealed the hole permenantly which also solved the smoke screen issue with the 2nd turbo. You just have to suck out the standing oil when you change the oil filter which is easy to do when you are using a suction oil extractor. 2012 TDV8 Vogue (L322) |
Yes, about a month ago, 2 x 5L of C1 Oil filter removed this morning and checked, all seems and looks sound - thank you for the tip Kevin ![]() |
No did not change "Oil Cooler" , only the two gaskets and 2 little turbo " O Rings " behind the oil cooler NB the oil cooler was inspected and no signs of cracks or warps, to the naked eye anyways - thx Reggie ![]() |
Hi Jaygee, the rubber seemed OK, not super pliable though, so it may well be hardening and not selaing properly, I think it might be worth replacing anyway, do you have the Part Number so I can order one today, thank you ![]() |
Am really struggling to get to the bottom of my excessive oil consumption, nearly 2 litres over 1000 miles, and have a 500 mile round trip to Exeter this weekend, so am concerned, but it must be burning oil, as nothing is dripping on to the driveway after being parked up for 2 days.
Have a look at the MAP sensor Pete.
. It's not available as a spare part - I just plugged mine with a self tapping screw and some PTFE tape. 2012 TDV8 Vogue (L322) |
Will do Kevin, MAP sensor circled in Blue from memory - thanks for the heads up ![]() |
@Kevin - well cleaning the MAP sensor with carb cleaner and an old toothbrush has done the trick, no oil loss after having just completed a 500 mile trip, and oil is just above normal, same as it was before I set off, so will now monitor for another 500 miles |
