Home > Technical (L322) > Bad Oil Leak and Oil Filter Housing Block Assembly
pcourtney
Interesting TDV8 4.4 2011 car
I replaced the two o rings behind the oil cooler two months ago and I am still topping up oil every month, some months it's over 1 litre, so I have to get to the bottom of this !
I have also replaced the Oil Cooler gaskets and rocker gaskets ( aka valve cover gaskets on both sides of the VCool
Coould the oil filter housing block assembly be the culprit ??
Post #696052 12th Jul 2024 9:45am
kevinp
Is it actually leaking oil or is it just using oil?
Post #696055 12th Jul 2024 10:07am
pcourtney
I have some drops on the driveway, and the smell of oil in the cabin when I pull up to traffic lights etc
Also after a long 200 mile trip to Exeter, I popped the bonnet and could see mist coming from the rear injectors - this is the battery side for RHD cars, a location which is above the secondary turbo, so hope its not the turbo Sad
Am using the correct Low SAPS C1 oil at £6 a litre
PETRONAS Syntium 5000 FJ 5W-30 C1 Fully Synthetic Car Engine Oil
Post #696059 12th Jul 2024 10:27am
kevinp
Have you done an oil change recently?
I've discovered that the oil filter drain back valve directly under the filter can come off it's locating post.
Worth whipping the oil filter out for a check. That wouldn't explain an external leak though.
Post #696060 12th Jul 2024 10:31am
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
Did you replace the oil cooler itself when you did the gasket and 'O' rings? They have a tendency to warp or even crack so replacing the gasket and 'O' rings alone might not fix a leak? _______________________________________________
2019 4.4 V8 Diesel Range Rover Autobiography, Byron Blue
Post #696065 12th Jul 2024 11:14am
JayGee
Defo check the oil fiter drain off valve and even if it's not off it's locating post the rubber goes hard and stops sealing properly. I removed mine and sealed the hole permenantly which also solved the smoke screen issue with the 2nd turbo. You just have to suck out the standing oil when you change the oil filter which is easy to do when you are using a suction oil extractor. 2012 TDV8 Vogue (L322)
Post #696068 12th Jul 2024 1:10pm
pcourtney
Yes, about a month ago, 2 x 5L of C1
Oil filter removed this morning and checked, all seems and looks sound - thank you for the tip Kevin Smile
Post #696431 18th Jul 2024 9:49am
pcourtney
No did not change "Oil Cooler" , only the two gaskets and 2 little turbo " O Rings " behind the oil cooler
NB the oil cooler was inspected and no signs of cracks or warps, to the naked eye anyways - thx Reggie Smile
Post #696432 18th Jul 2024 9:51am
pcourtney
Hi Jaygee, the rubber seemed OK, not super pliable though, so it may well be hardening and not selaing properly, I think it might be worth replacing anyway, do you have the Part Number so I can order one today, thank you Smile
Post #696433 18th Jul 2024 9:54am
pcourtney
Am really struggling to get to the bottom of my excessive oil consumption, nearly 2 litres over 1000 miles, and have a 500 mile round trip to Exeter this weekend, so am concerned, but it must be burning oil, as nothing is dripping on to the driveway after being parked up for 2 days.
I know it's normal for the 4.4 TDV8 to use a little oil, mainly small losses over time from the secondary turbo, plus the usual little bit of gunk running through the charged air system but, over a typical service period of approx 7,000 miles, they only lose about 200ml (which on an engine holding nearly 10 litres of oil is more than acceptable).
They are not known for burning through oil otherwise, more so from leaks, which was where I focused my efforts, so I replaced the rocker cover gaskets both sides, removed the 8 injectors and replaced the seals, replaced both oil cooler gaskets, took off the air intercooler elbow pipe and used 3 large o-rings to get a better seal, this seems to have stopped the misting of oil around that area for now !
Hope its not turbo related ?
Post #696435 18th Jul 2024 10:03am
kevinp
Have a look at the MAP sensor Pete.
Mine usually has damp crud on it but when my filter valve came off the MAP sensor was soaking wet with oil.
Mine was using oil at the same rate as yours but not used a drop since.
Can you take a photo of your valve?
Post #696448 18th Jul 2024 3:16pm
JayGee
It's not available as a spare part - I just plugged mine with a self tapping screw and some PTFE tape. 2012 TDV8 Vogue (L322)
Post #696452 18th Jul 2024 3:49pm
pcourtney
kevinp wrote:
Have a look at the MAP sensor Pete. Mine usually has damp crud on it but when my filter valve came off the MAP sensor was soaking wet with oil. Mine was using oil at the same rate as yours but not used a drop since. Can you take a photo of your valve?
Will do Kevin, MAP sensor circled in Blue from memory - thanks for the heads up Smile
Post #696459 18th Jul 2024 7:03pm
kevinp
Post #696464 18th Jul 2024 8:30pm
pcourtney
@Kevin - well cleaning the MAP sensor with carb cleaner and an old toothbrush has done the trick, no oil loss after having just completed a 500 mile trip, and oil is just above normal, same as it was before I set off, so will now monitor for another 500 miles Smile
NB both readings taken when parked up for over 12 hours on level ground ( so cold oil )
What I can't really figure out is why the TDV8 consumes so much oil when the MAP is clogged up with soot and carbon deposits, and after reading up on Manifold Absolute Pressure sensor article below, I am more informed but none the wiser
https://www.aa1car.com/library/map_sensors.htm
Am going to add the cleaning of the MAP sensor to my monthly list of tasks, it only takes 5 mins Smile
Post #696723 23rd Jul 2024 12:00pm
