Home > Maintenance & Mods (L322) > Oil change 2011 4.4 tdv8
Bobbds
Hello all, looking for advice ; new to me 2011 4.4 tdv8, dropped approx 8 litres out of the drain tube( couldn’t loosen the turbo drain plug) , put in 8.5, idled for 10 mins then left for 15 mins, Reading underfilled, repeated the idle/settle twice, still telling me undergilled.
Check on Rimmer Bros , tells me 9.5 litre capacity so topped up to 9.5, idled, rested twice more, left overnight, still telling me underfilled.
I’ve got a suction pump coming tomorrow, should I just drain from above then re-fill to try again?
Or have I got a faulty sensor?
Post #695464 3rd Jul 2024 10:37am
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
Maybe a silly question, but are you on level ground? The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #695466 3rd Jul 2024 11:01am
Bobbds
Yes, concrete garage floor, car up on four of the black plastic ramps, seems to be on the horizontal
Post #695467 3rd Jul 2024 12:34pm
Bobbds
Btw JMC, at my newbie level of knowledge and competence there are no silly questions
Post #695468 3rd Jul 2024 12:35pm
JayGee
Was it showing the correct level before you drained the oil ? 2012 TDV8 Vogue (L322)
Post #695475 3rd Jul 2024 2:31pm
Bobbds
Rookie error, didn’t check😞
Post #695477 3rd Jul 2024 3:32pm
JayGee
Put another litre in and if it still doesn't show on the display drain it all and fill with 9.5 L and look at getting the level sensor replaced. 2012 TDV8 Vogue (L322)
Post #695481 3rd Jul 2024 4:07pm
Bobbds
Thanks Jaygee : I only have a half litre left but I thought I might throw that in and see what happens : worst case scenario I’ll pump it back out and order a sensor.
Wouldn’t 10 litres be excessive in any event?
Particularly since I couldn’t get the turbo drain plug undone
Post #695482 3rd Jul 2024 4:11pm
JayGee
10L won't do any harm. I've had 10L out when I drained it from cold ( took a long time mind) . It's not crucial to get the turbo drain plug undone. 2012 TDV8 Vogue (L322)
Post #695483 3rd Jul 2024 4:18pm
Bobbds
I’ll have a go.
Thanks for your advice
Post #695484 3rd Jul 2024 4:34pm
Baltic Blue
I am not sure 10 litres is wise.
Anything over 8.5 litres of new cold oil on mine gives the following warning once it’s up to normal running temperature.
The good news though is that changing the sensor on an L322 is relatively easy because it mounts under the sump, as opposed to the L405 being inside the sump.
Post #695489 3rd Jul 2024 6:39pm
Bobbds
Hi Mike, thanks for your advice.
I’m pretty sure it is the sensor-now not giving a reading , so I’ll order one and extract 1.5 litres , hopefully that’ll resolve matters.
Post #695493 3rd Jul 2024 6:58pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
By the “book”, the service refill is 9.5 litres
This gives me an overfill
So when i drain, i put 9 back in. Some prefer 8.5 and then top up to desired level
When i vacuum extract, i put back in what i took out
Post #695528 4th Jul 2024 2:46pm
JayGee
Not sure how accurate the guage is so maybe best to put in the recommened amount and ignore any over fill on the readout 2012 TDV8 Vogue (L322)
Post #695529 4th Jul 2024 3:02pm
