Home > Maintenance & Mods (L322) > Oil change 2011 4.4 tdv8 |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 755 |
Maybe a silly question, but are you on level ground? The older I get, the more I realise that people confuse wrinkles for wisdom |
3rd Jul 2024 11:01am |
Bobbds Member Since: 30 May 2024 Location: Scottish Highlands Posts: 7 |
Yes, concrete garage floor, car up on four of the black plastic ramps, seems to be on the horizontal |
3rd Jul 2024 12:34pm |
Btw JMC, at my newbie level of knowledge and competence there are no silly questions |
3rd Jul 2024 12:35pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3188 |
Was it showing the correct level before you drained the oil ? 2012 TDV8 Vogue (L322) |
3rd Jul 2024 2:31pm |
Rookie error, didn’t check😞 |
3rd Jul 2024 3:32pm |
Put another litre in and if it still doesn't show on the display drain it all and fill with 9.5 L and look at getting the level sensor replaced. 2012 TDV8 Vogue (L322) |
3rd Jul 2024 4:07pm |
Thanks Jaygee : I only have a half litre left but I thought I might throw that in and see what happens : worst case scenario I’ll pump it back out and order a sensor.
3rd Jul 2024 4:11pm |
10L won't do any harm. I've had 10L out when I drained it from cold ( took a long time mind) . It's not crucial to get the turbo drain plug undone. 2012 TDV8 Vogue (L322) |
3rd Jul 2024 4:18pm |
I’ll have a go.
3rd Jul 2024 4:34pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3763 |
I am not sure 10 litres is wise.
3rd Jul 2024 6:39pm |
Hi Mike, thanks for your advice.
3rd Jul 2024 6:58pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 798 |
By the “book”, the service refill is 9.5 litres
4th Jul 2024 2:46pm |
Not sure how accurate the guage is so maybe best to put in the recommened amount and ignore any over fill on the readout 2012 TDV8 Vogue (L322) |
4th Jul 2024 3:02pm |
