![]() | Home > Maintenance & Mods (L322) > Oil change 2011 4.4 tdv8 |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 779 ![]() ![]() ![]() |
Maybe a silly question, but are you on level ground? The older I get, the more I realise that people confuse wrinkles for wisdom |
Bobbds Member Since: 30 May 2024 Location: Scottish Highlands Posts: 7 ![]() ![]() |
Yes, concrete garage floor, car up on four of the black plastic ramps, seems to be on the horizontal |
Btw JMC, at my newbie level of knowledge and competence there are no silly questions |
Was it showing the correct level before you drained the oil ? 2012 TDV8 Vogue (L322) |
Rookie error, didn’t check😞 |
Put another litre in and if it still doesn't show on the display drain it all and fill with 9.5 L and look at getting the level sensor replaced. 2012 TDV8 Vogue (L322) |
Thanks Jaygee : I only have a half litre left but I thought I might throw that in and see what happens : worst case scenario I’ll pump it back out and order a sensor.
10L won't do any harm. I've had 10L out when I drained it from cold ( took a long time mind) . It's not crucial to get the turbo drain plug undone. 2012 TDV8 Vogue (L322) |
I’ll have a go.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3817 ![]() ![]() ![]() |
I am not sure 10 litres is wise.
Mike. G reg 2.5VM Vogue Portofino red 1991- 1999 V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
Hi Mike, thanks for your advice.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 818 ![]() ![]() |
By the “book”, the service refill is 9.5 litres
Not sure how accurate the guage is so maybe best to put in the recommened amount and ignore any over fill on the readout 2012 TDV8 Vogue (L322) |
